mikegmoney
has anyone figured out how to get a wifi hotspot with the warp yet? trying to get wifi tether to my tablet from my warp...
Yeah my password has never worked but are u saying tablets won't pick up our wifi tether?? I tether to a laptop and I can assure it works I use it every day
IMO its the best oneI gamed off mine for quite a while because I couldn't afford cable/internet. It kills your battery so fast and if you plug it up and tether then your phone gets BLAZING hot. There are always downsides to tricks, but if it's not illegal and we can keep the temp down then have at it.
By the way the temp shouldn't get over 100 degrees. If you do then unplug your phone.. Cut off the wifi and let it air out. DO NOT remove battery. Just take off the back case and let it breathe.
