Root [Boost Mobile] How to truly unbrick your SGS3 - Boost SGS3
Thanks for getting back to me, as much as I was reading I didn't even see that this forum was for Boost. I have not been able to find the Sprint SGS3 image for 4.3, finally started posting in hopes that there might be one out there. Figures I would post it in the wrong place. Sorry!
Ouch isn't even the right word, keep on the lookout for a news headline reading "Woman commits suicide via bricked cellular device..." lol
Are these what you're looking for?
4.3 Sprint image:
4.3 Debrick image - xda-developers[/url]
4.4 Sprint Image:
[url=http://forum.xda-developers.com/showthread.php?t=2740469][IMG][ND8] Kitkat Debrick images - xda-developers[/url]
Well here goes nothing........all i know is so far I am in the hole $20 for the SD card and one pissed off wife XD........crossing my fingers this works. I never messed w linux before
Got the linux mint live cd going just fine......
1. linux is running
2. opened terminal
3. inserted SD card
4. typed dmesg | tail
I am getting a bunch of code and nothing more......
mint@mint ~ $ dmesg | tail
[ 414.891723] cfg80211: Regulatory domain changed to country: US
[ 414.891729] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 414.891733] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2700 mBm)
[ 414.891737] cfg80211: (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 1700 mBm)
[ 414.891740] cfg80211: (5250000 KHz - 5330000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 414.891743] cfg80211: (5490000 KHz - 5600000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 414.891746] cfg80211: (5650000 KHz - 5710000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 414.891749] cfg80211: (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 3000 mBm)
[ 414.891752] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4000 mBm)
[ 1265.064851] perf samples too long (2512 > 2500), lowering kernel.perf_event_max_sample_rate to 50000
tried the same thing with a space instead of a | and got this.....
[ 4.347240] ehci-pci 0000:00:1d.0: new USB bus registered, assigned bus number 2
[ 4.347258] ehci-pci 0000:00:1d.0: debug port 2
[ 4.351201] ACPI: Battery Slot [BAT1] (battery present)
[ 4.351226] ehci-pci 0000:00:1d.0: cache line size of 64 is not supported
[ 4.351242] ehci-pci 0000:00:1d.0: irq 23, io mem 0xf6007000
[ 4.362816] ehci-pci 0000:00:1d.0: USB 2.0 started, EHCI 1.00
[ 4.362945] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 4.362950] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.362953] usb usb2: Product: EHCI Host Controller
[ 4.362956] usb usb2: Manufacturer: Linux 3.13.0-24-generic ehci_hcd
[ 4.362959] usb usb2: SerialNumber: 0000:00:1d.0
[ 4.363253] hub 2-0:1.0: USB hub found
[ 4.363269] hub 2-0:1.0: 2 ports detected
[ 4.363419] ehci-platform: EHCI generic platform driver
[ 4.363430] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 4.363432] ohci-pci: OHCI PCI platform driver
[ 4.363445] ohci-platform: OHCI generic platform driver
[ 4.363453] uhci_hcd: USB Universal Host Controller Interface driver
[ 4.363539] i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PSM1] at 0x60,0x64 irq 1,12
[ 4.366851] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 4.366856] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 4.367329] mousedev: PS/2 mouse device common for all mice
[ 4.368534] rtc_cmos 00:05: rtc core: registered rtc_cmos as rtc0
[ 4.368577] rtc_cmos 00:05: alarms up to one year, y3k, 242 bytes nvram, hpet irqs
[ 4.368700] device-mapper: uevent: version 1.0.3
[ 4.368955] device-mapper: ioctl: 4.27.0-ioctl (2013-10-30) initialised: dm-devel@redhat.com
[ 4.368969] ledtrig-cpu: registered to indicate activity on CPUs
[ 4.369158] TCP: cubic registered
[ 4.369335] NET: Registered protocol family 10
[ 4.369693] NET: Registered protocol family 17
[ 4.369714] Key type dns_resolver registered
[ 4.370480] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input4
[ 4.370875] Loading compiled-in X.509 certificates
[ 4.372880] Loaded X.509 cert 'Magrathea: Glacier signing key: 00a5a65759de474bc5c43120880c1b94a539f431'
[ 4.372901] registered taskstats version 1
[ 4.378020] Key type trusted registered
[ 4.382752] Key type encrypted registered
[ 4.387332] AppArmor: AppArmor sha1 policy hashing enabled
[ 4.387338] IMA: No TPM chip found, activating TPM-bypass!
[ 4.388109] regulator-dummy: disabling
[ 4.388284] Magic number: 6:518:585
[ 4.388473] rtc_cmos 00:05: setting system clock to 2014-07-28 13:35:44 UTC (1406554544)
[ 4.389325] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[ 4.389327] EDD information not available.
[ 4.389379] PM: Hibernation image not present or could not be loaded.
[ 4.390628] Freeing unused kernel memory: 1332K (ffffffff81d1e000 - ffffffff81e6b000)
[ 4.390631] Write protecting the kernel read-only data: 12288k
[ 4.392608] Freeing unused kernel memory: 844K (ffff88000172d000 - ffff880001800000)
[ 4.394178] Freeing unused kernel memory: 708K (ffff880001b4f000 - ffff880001c00000)
[ 4.410669] systemd-udevd[124]: starting version 204
[ 4.424808] wmi: Mapper loaded
[ 4.439676] sky2: driver version 1.30
[ 4.440137] sky2 0000:03:00.0: Yukon-2 Optima chip revision 1
[ 4.440619] sky2 0000:03:00.0: irq 41 for MSI/MSI-X
[ 4.440866] [drm] Initialized drm 1.1.0 20060810
[ 4.441688] sky2 0000:03:00.0 eth0: addr e8:11:32:0b:b4:6f
[ 4.445943] ahci 0000:00:1f.2: version 3.0
[ 4.446215] ahci 0000:00:1f.2: irq 42 for MSI/MSI-X
[ 4.446300] ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 4 ports 3 Gbps 0x3 impl SATA mode
[ 4.446304] ahci 0000:00:1f.2: flags: 64bit ncq sntf pm led clo pio slum part ems apst
[ 4.451196] scsi0 : ahci
[ 4.451302] scsi1 : ahci
[ 4.451374] scsi2 : ahci
[ 4.451446] scsi3 : ahci
[ 4.451493] ata1: SATA max UDMA/133 abar m2048@0xf6006000 port 0xf6006100 irq 42
[ 4.451497] ata2: SATA max UDMA/133 abar m2048@0xf6006000 port 0xf6006180 irq 42
[ 4.451499] ata3: DUMMY
[ 4.451500] ata4: DUMMY
[ 4.459158] [drm] Memory usable by graphics device = 2048M
[ 4.478181] MXM: GUID detected in BIOS
[ 4.478208] ACPI Warning: \_SB_.PCI0.GFX0._DSM: Argument #4 type mismatch - Found [Integer], ACPI requires [Package] (20131115/nsarguments-95)
[ 4.478488] ACPI Warning: \_SB_.PCI0.GFX0._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20131115/nsarguments-95)
[ 4.478827] ACPI Warning: \_SB_.PCI0.GFX0._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20131115/nsarguments-95)
[ 4.479198] i915 0000:00:02.0: optimus capabilities: enabled, status dynamic power,
[ 4.479212] ACPI Warning: \_SB_.PCI0.P0P2.PEGP._DSM: Argument #4 type mismatch - Found [Integer], ACPI requires [Package] (20131115/nsarguments-95)
[ 4.479340] ACPI Warning: \_SB_.PCI0.P0P2.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20131115/nsarguments-95)
[ 4.479552] ACPI Warning: \_SB_.PCI0.P0P2.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20131115/nsarguments-95)
[ 4.479794] pci 0000:01:00.0: optimus capabilities: enabled, status dynamic power,
[ 4.479799] VGA switcheroo: detected Optimus DSM method \_SB_.PCI0.P0P2.PEGP handle
[ 4.510852] i915 0000:00:02.0: irq 43 for MSI/MSI-X
[ 4.510873] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 4.510876] [drm] Driver supports precise vblank timestamp query.
[ 4.511248] vgaarb: device changed decodes: PCI:0000:00:02.0,olddecodes=io+mem,decodes=io+mem:owns=io+mem
[ 4.553312] fbcon: inteldrmfb (fb0) is primary device
[ 4.646892] usb 1-1: new high-speed USB device number 2 using ehci-pci
[ 4.770838] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 4.770883] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 4.771165] ata2.00: ATAPI: TSSTcorp CDDVDW TS-U633F, SC00, max UDMA/100
[ 4.771168] ata2.00: applying bridge limits
[ 4.771772] ata2.00: configured for UDMA/100
[ 4.777276] ata1.00: ATA-8: SAMSUNG HM641JI, 2AJ10002, max UDMA/133
[ 4.777279] ata1.00: 1250263728 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
[ 4.779569] usb 1-1: New USB device found, idVendor=8087, idProduct=0020
[ 4.779571] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 4.779990] hub 1-1:1.0: USB hub found
[ 4.780063] hub 1-1:1.0: 6 ports detected
[ 4.783688] ata1.00: configured for UDMA/133
[ 4.783984] scsi 0:0:0:0: Direct-Access ATA SAMSUNG HM641JI 2AJ1 PQ: 0 ANSI: 5
[ 4.784194] sd 0:0:0:0: [sda] 1250263728 512-byte logical blocks: (640 GB/596 GiB)
[ 4.784210] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 4.784264] sd 0:0:0:0: [sda] Write Protect is off
[ 4.784266] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 4.784300] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 4.784937] scsi 1:0:0:0: CD-ROM TSSTcorp CDDVDW TS-U633F SC00 PQ: 0 ANSI: 5
[ 4.789877] sr0: scsi3-mmc drive: 31x/62x writer dvd-ram cd/rw xa/form2 cdda tray
[ 4.789879] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 4.790119] sr 1:0:0:0: Attached scsi CD-ROM sr0
[ 4.790209] sr 1:0:0:0: Attached scsi generic sg1 type 5
[ 4.890952] usb 2-1: new high-speed USB device number 2 using ehci-pci
[ 5.023282] usb 2-1: New USB device found, idVendor=8087, idProduct=0020
[ 5.023284] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 5.023863] hub 2-1:1.0: USB hub found
[ 5.023957] hub 2-1:1.0: 8 ports detected
[ 5.095038] usb 1-1.4: new high-speed USB device number 3 using ehci-pci
[ 5.150345] sda: sda1 sda2 sda3
[ 5.150812] sd 0:0:0:0: [sda] Attached SCSI disk
[ 5.182872] tsc: Refined TSC clocksource calibration: 2659.999 MHz
[ 5.212655] usb 1-1.4: New USB device found, idVendor=1210, idProduct=2604
[ 5.212658] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 5.212660] usb 1-1.4: Product: WebCam SCB-0380M
[ 5.212663] usb 1-1.4: Manufacturer: Alcor Micro, Corp.
[ 5.241438] Console: switching to colour frame buffer device 170x48
[ 5.243943] i915 0000:00:02.0: fb0: inteldrmfb frame buffer device
[ 5.243944] i915 0000:00:02.0: registered panic notifier
[ 5.244153] ACPI Exception: AE_NOT_FOUND, Evaluating _DOD (20131115/video-1246)
[ 5.244157] ACPI: Video Device [PEGP] (multi-head: no rom: yes post: no)
[ 5.244200] input: Video Bus as /devices/LNXSYSTM:00/device:00/PNP0A08:00/device:07/LNXVIDEO:00/input/input6
[ 5.251559] ACPI: Video Device [GFX0] (multi-head: yes rom: no post: no)
[ 5.252568] acpi device:09: registered as cooling_device6
[ 5.252625] input: Video Bus as /devices/LNXSYSTM:00/device:00/PNP0A08:00/LNXVIDEO:01/input/input7
[ 5.252723] [drm] Initialized i915 1.6.0 20080730 for 0000:00:02.0 on minor 0
[ 5.253035] [drm] hdmi device not found 1 0 1
[ 5.253188] nouveau [ DEVICE][0000:01:00.0] BOOT0 : 0x0a8800b1
[ 5.253192] nouveau [ DEVICE][0000:01:00.0] Chipset: GT218 (NVA8)
[ 5.253194] nouveau [ DEVICE][0000:01:00.0] Family : NV50
[ 5.254637] nouveau [ VBIOS][0000:01:00.0] checking PRAMIN for image...
[ 5.254660] nouveau [ VBIOS][0000:01:00.0] ... signature not found
[ 5.254662] nouveau [ VBIOS][0000:01:00.0] checking PROM for image...
[ 5.254727] nouveau [ VBIOS][0000:01:00.0] ... signature not found
[ 5.254729] nouveau [ VBIOS][0000:01:00.0] checking ACPI for image...
[ 5.299062] usb 2-1.3: new high-speed USB device number 3 using ehci-pci
[ 5.391795] usb 2-1.3: New USB device found, idVendor=8086, idProduct=0186
[ 5.391801] usb 2-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 5.391805] usb 2-1.3: Product: Intel(R) Centrino(R) Advanced-N + WiMAX 6250
[ 5.391809] usb 2-1.3: Manufacturer: Intel(R) Corporation
[ 5.463084] usb 2-1.4: new high-speed USB device number 4 using ehci-pci
[ 5.560060] usb 2-1.4: New USB device found, idVendor=05e3, idProduct=0727
[ 5.560066] usb 2-1.4: New USB device strings: Mfr=3, Product=4, SerialNumber=2
[ 5.560070] usb 2-1.4: Product: USB Storage
[ 5.560074] usb 2-1.4: Manufacturer: Generic
[ 5.560077] usb 2-1.4: SerialNumber: 000000000207
[ 5.563791] usb-storage 2-1.4:1.0: USB Mass Storage device detected
[ 5.563893] scsi4 : usb-storage 2-1.4:1.0
[ 5.563954] usbcore: registered new interface driver usb-storage
[ 6.122887] random: nonblocking pool is initialized
[ 6.183222] Switched to clocksource tsc
[ 6.564929] scsi 4:0:0:0: Direct-Access Generic STORAGE DEVICE 0207 PQ: 0 ANSI: 0
[ 6.565556] sd 4:0:0:0: Attached scsi generic sg2 type 0
[ 6.676806] sd 4:0:0:0: [sdb] 30703616 512-byte logical blocks: (15.7 GB/14.6 GiB)
[ 6.678192] sd 4:0:0:0: [sdb] Write Protect is off
[ 6.678198] sd 4:0:0:0: [sdb] Mode Sense: 0b 00 00 08
[ 6.679577] sd 4:0:0:0: [sdb] No Caching mode page found
[ 6.679583] sd 4:0:0:0: [sdb] Assuming drive cache: write through
[ 6.684553] sd 4:0:0:0: [sdb] No Caching mode page found
[ 6.684560] sd 4:0:0:0: [sdb] Assuming drive cache: write through
[ 6.685835] sdb: sdb1
[ 6.690069] sd 4:0:0:0: [sdb] No Caching mode page found
[ 6.690075] sd 4:0:0:0: [sdb] Assuming drive cache: write through
[ 6.690080] sd 4:0:0:0: [sdb] Attached SCSI removable disk
[ 6.819223] nouveau [ VBIOS][0000:01:00.0] ... appears to be valid
[ 6.819226] nouveau [ VBIOS][0000:01:00.0] using image from ACPI
[ 6.819310] nouveau [ VBIOS][0000:01:00.0] BIT signature found
[ 6.819312] nouveau [ VBIOS][0000:01:00.0] version 70.18.6c.00.0c
[ 6.819542] nouveau [ DEVINIT][0000:01:00.0] adaptor not initialised
[ 6.819545] nouveau [ VBIOS][0000:01:00.0] running init tables
[ 6.889716] nouveau 0000:01:00.0: irq 44 for MSI/MSI-X
[ 6.889739] nouveau [ PMC][0000:01:00.0] MSI interrupts enabled
[ 6.889787] nouveau [ PFB][0000:01:00.0] RAM type: DDR3
[ 6.889788] nouveau [ PFB][0000:01:00.0] RAM size: 512 MiB
[ 6.889789] nouveau [ PFB][0000:01:00.0] ZCOMP: 960 tags
[ 6.895847] nouveau [ VOLT][0000:01:00.0] GPU voltage: 850000uv
[ 6.918670] nouveau [ PTHERM][0000:01:00.0] FAN control: none / external
[ 6.918676] nouveau [ PTHERM][0000:01:00.0] fan management: automatic
[ 6.918682] nouveau [ PTHERM][0000:01:00.0] internal sensor: yes
[ 6.918734] nouveau [ CLK][0000:01:00.0] 07: core 405 MHz shader 810 MHz memory 405 MHz
[ 6.918738] nouveau [ CLK][0000:01:00.0] 0f: core 606 MHz shader 1468 MHz memory 790 MHz
[ 6.918778] nouveau [ CLK][0000:01:00.0] --: core 405 MHz shader 810 MHz memory 405 MHz
[ 6.918833] vga_switcheroo: enabled
[ 6.919040] [TTM] Zone kernel: Available graphics memory: 1915532 kiB
[ 6.919045] [TTM] Initializing pool allocator
[ 6.919054] [TTM] Initializing DMA pool allocator
[ 6.919075] nouveau [ DRM] VRAM: 512 MiB
[ 6.919078] nouveau [ DRM] GART: 1048576 MiB
[ 6.919085] nouveau [ DRM] TMDS table version 2.0
[ 6.919089] nouveau [ DRM] DCB version 4.0
[ 6.919093] nouveau [ DRM] DCB outp 00: 02010300 00000000
[ 6.919097] nouveau [ DRM] DCB conn 00: 00000100
[ 6.954919] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 6.954921] [drm] No driver support for vblank timestamp query.
[ 6.954924] nouveau [ DRM] ACPI backlight interface available, not registering our own
[ 6.994463] nouveau [ DRM] MM: using COPY for buffer copies
[ 6.994478] [drm] Initialized nouveau 1.1.1 20120801 for 0000:01:00.0 on minor 1
[ 9.652334] ISO 9660 Extensions: Microsoft Joliet Level 3
[ 9.655860] ISO 9660 Extensions: RRIP_1991A
[ 10.301923] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 11.991533] ACPI Warning: \_SB_.PCI0.P0P2.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20131115/nsarguments-95)
[ 11.991717] ACPI Warning: \_SB_.PCI0.P0P2.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20131115/nsarguments-95)
[ 70.230120] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 72.323175] systemd-udevd[1027]: starting version 204
[ 78.274933] init: cups main process (1085) killed by HUP signal
[ 78.274946] init: cups main process ended, respawning
[ 79.166288] lp: driver loaded but no devices found
[ 79.846012] ppdev: user-space parallel port driver
[ 80.204566] Bluetooth: Core ver 2.17
[ 80.204593] NET: Registered protocol family 31
[ 80.204594] Bluetooth: HCI device and connection manager initialized
[ 80.204606] Bluetooth: HCI socket layer initialized
[ 80.204609] Bluetooth: L2CAP socket layer initialized
[ 80.204614] Bluetooth: SCO socket layer initialized
[ 82.382186] intel ips 0000:00:1f.6: CPU TDP doesn't match expected value (found 25, expected 29)
[ 82.385143] intel ips 0000:00:1f.6: IPS driver initialized, MCP temp limit 90
[ 82.642659] Bluetooth: RFCOMM TTY layer initialized
[ 82.642673] Bluetooth: RFCOMM socket layer initialized
[ 82.642680] Bluetooth: RFCOMM ver 1.11
[ 83.509431] ACPI Warning: 0x0000000000000428-0x000000000000042f SystemIO conflicts with Region \PMIO 1 (20131115/utaddress-251)
[ 83.509440] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 83.509445] ACPI Warning: 0x0000000000000540-0x000000000000054f SystemIO conflicts with Region \GPIO 1 (20131115/utaddress-251)
[ 83.509449] ACPI Warning: 0x0000000000000540-0x000000000000054f SystemIO conflicts with Region \_SB_.PCI0.P0P2.PEGP.GPIO 2 (20131115/utaddress-251)
[ 83.509453] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 83.509455] ACPI Warning: 0x0000000000000530-0x000000000000053f SystemIO conflicts with Region \GPIO 1 (20131115/utaddress-251)
[ 83.509458] ACPI Warning: 0x0000000000000530-0x000000000000053f SystemIO conflicts with Region \_SB_.PCI0.P0P2.PEGP.GPIO 2 (20131115/utaddress-251)
[ 83.509462] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 83.509464] ACPI Warning: 0x0000000000000500-0x000000000000052f SystemIO conflicts with Region \GPIO 1 (20131115/utaddress-251)
[ 83.509467] ACPI Warning: 0x0000000000000500-0x000000000000052f SystemIO conflicts with Region \_SB_.PCI0.P0P2.PEGP.GPIO 2 (20131115/utaddress-251)
[ 83.509471] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 83.509473] lpc_ich: Resource conflict(s) found affecting gpio_ich
[ 84.158695] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 84.158701] Bluetooth: BNEP filters: protocol multicast
[ 84.158713] Bluetooth: BNEP socket layer initialized
[ 84.171097] cfg80211: Calling CRDA to update world regulatory domain
[ 84.757744] mei_me 0000:00:16.0: irq 45 for MSI/MSI-X
[ 86.716574] Intel(R) Wireless WiFi driver for Linux, in-tree:
[ 86.716579] Copyright(c) 2003-2013 Intel Corporation
[ 86.716847] iwlwifi 0000:02:00.0: can't disable ASPM; OS doesn't have ASPM control
[ 86.716926] iwlwifi 0000:02:00.0: irq 46 for MSI/MSI-X
[ 86.723649] kvm: VM_EXIT_LOAD_IA32_PERF_GLOBAL_CTRL does not work properly. Using workaround
[ 87.156743] psmouse serio1: elantech: assuming hardware version 3 (with firmware version 0x851b00)
[ 87.171016] psmouse serio1: elantech: Synaptics capabilities query result 0x19, 0x14, 0x0c.
[ 87.245687] input: ETPS/2 Elantech Touchpad as /devices/platform/i8042/serio1/input/input8
[ 87.829762] iwlwifi 0000:02:00.0: loaded firmware version 41.28.5.1 build 33926 op_mode iwldvm
[ 88.534233] Linux video capture interface: v2.00
[ 89.484838] device-mapper: multipath: version 1.6.0 loaded
[ 90.200642] i2400m_usb 2-1.3:1.0: WiMAX interface wmx0 (64:d4:da:1c:2b:ac) ready
[ 90.289116] samsung_laptop: detected SABI interface: SwSmi@
[ 90.289120] samsung_laptop: Backlight controlled by ACPI video driver
[ 91.551121] uvcvideo: Found UVC 1.00 device WebCam SCB-0380M (1210:2604)
[ 91.553901] input: WebCam SCB-0380M as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.4/1-1.4:1.0/input/input9
[ 91.554069] usbcore: registered new interface driver uvcvideo
[ 91.554071] USB Video Class driver (1.1.1)
[ 92.278101] snd_hda_intel 0000:00:1b.0: irq 47 for MSI/MSI-X
[ 92.322290] init: failsafe main process (1277) killed by TERM signal
[ 93.190857] SKU: Nid=0x1d sku_cfg=0x40059a05
[ 93.190861] SKU: port_connectivity=0x1
[ 93.190863] SKU: enable_pcbeep=0x0
[ 93.190864] SKU: check_sum=0x00000005
[ 93.190865] SKU: customization=0x0000009a
[ 93.190866] SKU: external_amp=0x0
[ 93.190867] SKU: platform_type=0x1
[ 93.190868] SKU: swap=0x0
[ 93.190869] SKU: override=0x1
[ 93.191380] autoconfig: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
[ 93.191382] speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 93.191383] hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[ 93.191384] mono: mono_out=0x0
[ 93.191385] inputs:
[ 93.191387] Internal Mic=0x19
[ 93.191388] Mic=0x18
[ 93.191390] realtek: No valid SSID, checking pincfg 0x40059a05 for NID 0x1d
[ 93.191392] realtek: Enabling init ASM_ID=0x9a05 CODEC_ID=10ec0269
[ 93.705875] cfg80211: World regulatory domain updated:
[ 93.705881] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 93.705883] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 93.705884] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 93.705886] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[ 93.705887] cfg80211: (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 93.705888] cfg80211: (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 94.107115] input: HDA Intel MID HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1b.0/sound/card0/input12
[ 94.107336] input: HDA Intel MID Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input11
[ 94.107481] input: HDA Intel MID Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input10
[ 97.253703] iwlwifi 0000:02:00.0: CONFIG_IWLWIFI_DEBUG disabled
[ 97.253708] iwlwifi 0000:02:00.0: CONFIG_IWLWIFI_DEBUGFS enabled
[ 97.253709] iwlwifi 0000:02:00.0: CONFIG_IWLWIFI_DEVICE_TRACING enabled
[ 97.253711] iwlwifi 0000:02:00.0: Detected Intel(R) Centrino(R) Advanced-N + WiMAX 6250 AGN, REV=0x84
[ 97.253766] iwlwifi 0000:02:00.0: L1 Enabled; Disabling L0S
[ 99.756413] ieee80211 phy0: Selected rate control algorithm 'iwl-agn-rs'
[ 109.496466] i2400m_usb 2-1.3:1.0: firmware interface version 9.3.2
[ 109.504462] usbcore: registered new interface driver i2400m_usb
[ 114.956246] usb 2-1.4: USB disconnect, device number 4
[ 122.872507] iwlwifi 0000:02:00.0: L1 Enabled; Disabling L0S
[ 122.872718] iwlwifi 0000:02:00.0: Radio type=0x1-0x2-0x0
[ 123.096059] iwlwifi 0000:02:00.0: L1 Enabled; Disabling L0S
[ 123.096265] iwlwifi 0000:02:00.0: Radio type=0x1-0x2-0x0
[ 123.202191] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 123.204030] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 123.215766] sky2 0000:03:00.0 eth0: enabling interface
[ 123.216360] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 123.219007] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 123.225576] IPv6: ADDRCONF(NETDEV_UP): wmx0: link is not ready
[ 123.228222] IPv6: ADDRCONF(NETDEV_UP): wmx0: link is not ready
[ 127.844378] init: smbd main process (1343) killed by HUP signal
[ 127.844392] init: smbd main process ended, respawning
[ 137.869677] init: samba-ad-dc main process (1688) terminated with status 1
[ 140.494754] init: alsa-restore main process (1999) terminated with status 99
[ 146.830476] init: plymouth-upstart-bridge main process ended, respawning
[ 147.972783] ACPI Warning: \_SB_.PCI0.P0P2.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20131115/nsarguments-95)
[ 147.973017] ACPI Warning: \_SB_.PCI0.P0P2.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20131115/nsarguments-95)
[ 161.058049] ACPI Warning: \_SB_.PCI0.P0P2.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20131115/nsarguments-95)
[ 161.058280] ACPI Warning: \_SB_.PCI0.P0P2.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20131115/nsarguments-95)
[ 182.104063] ACPI Warning: \_SB_.PCI0.P0P2.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20131115/nsarguments-95)
[ 182.104214] ACPI Warning: \_SB_.PCI0.P0P2.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20131115/nsarguments-95)
[ 371.178656] usb 2-1.4: new high-speed USB device number 5 using ehci-pci
[ 371.275801] usb 2-1.4: New USB device found, idVendor=05e3, idProduct=0727
[ 371.275807] usb 2-1.4: New USB device strings: Mfr=3, Product=4, SerialNumber=2
[ 371.275810] usb 2-1.4: Product: USB Storage
[ 371.275813] usb 2-1.4: Manufacturer: Generic
[ 371.275816] usb 2-1.4: SerialNumber: 000000000207
[ 371.276713] usb-storage 2-1.4:1.0: USB Mass Storage device detected
[ 371.277607] scsi5 : usb-storage 2-1.4:1.0
[ 372.276299] scsi 5:0:0:0: Direct-Access Generic STORAGE DEVICE 0207 PQ: 0 ANSI: 0
[ 372.276882] sd 5:0:0:0: Attached scsi generic sg2 type 0
[ 372.388374] sd 5:0:0:0: [sdb] 30703616 512-byte logical blocks: (15.7 GB/14.6 GiB)
[ 372.389754] sd 5:0:0:0: [sdb] Write Protect is off
[ 372.389760] sd 5:0:0:0: [sdb] Mode Sense: 0b 00 00 08
[ 372.391363] sd 5:0:0:0: [sdb] No Caching mode page found
[ 372.391370] sd 5:0:0:0: [sdb] Assuming drive cache: write through
[ 372.396134] sd 5:0:0:0: [sdb] No Caching mode page found
[ 372.396141] sd 5:0:0:0: [sdb] Assuming drive cache: write through
[ 372.397398] sdb: sdb1
[ 372.401864] sd 5:0:0:0: [sdb] No Caching mode page found
[ 372.401867] sd 5:0:0:0: [sdb] Assuming drive cache: write through
[ 372.401869] sd 5:0:0:0: [sdb] Attached SCSI removable disk
[ 408.167932] systemd-hostnamed[3175]: Warning: nss-myhostname is not installed. Changing the local hostname might make it unresolveable. Please install nss-myhostname!
[ 414.753072] wlan0: authenticate with 00:26:f2:ea:36:9e
[ 414.762091] wlan0: send auth to 00:26:f2:ea:36:9e (try 1/3)
[ 414.866771] wlan0: send auth to 00:26:f2:ea:36:9e (try 2/3)
[ 414.868604] wlan0: authenticated
[ 414.870749] wlan0: associate with 00:26:f2:ea:36:9e (try 1/3)
[ 414.876893] wlan0: RX AssocResp from 00:26:f2:ea:36:9e (capab=0x431 status=0 aid=3)
[ 414.885640] wlan0: associated
[ 414.885694] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 414.885814] cfg80211: Calling CRDA for country: US
[ 2139.345935] usb 2-1.4: USB disconnect, device number 5
[ 2139.366709] FAT-fs (sdb1): unable to read boot sector to mark fs as dirty
[ 2140.822904] usb 2-1.4: new high-speed USB device number 6 using ehci-pci
[ 2140.919974] usb 2-1.4: New USB device found, idVendor=05e3, idProduct=0727
[ 2140.919982] usb 2-1.4: New USB device strings: Mfr=3, Product=4, SerialNumber=2
[ 2140.919987] usb 2-1.4: Product: USB Storage
[ 2140.919990] usb 2-1.4: Manufacturer: Generic
[ 2140.919994] usb 2-1.4: SerialNumber: 000000000207
[ 2140.920948] usb-storage 2-1.4:1.0: USB Mass Storage device detected
[ 2140.921033] scsi6 : usb-storage 2-1.4:1.0
[ 2141.920375] scsi 6:0:0:0: Direct-Access Generic STORAGE DEVICE 0207 PQ: 0 ANSI: 0
[ 2141.920778] sd 6:0:0:0: Attached scsi generic sg2 type 0
[ 2142.080199] sd 6:0:0:0: [sdb] 30703616 512-byte logical blocks: (15.7 GB/14.6 GiB)
[ 2142.081526] sd 6:0:0:0: [sdb] Write Protect is off
[ 2142.081531] sd 6:0:0:0: [sdb] Mode Sense: 0b 00 00 08
[ 2142.082766] sd 6:0:0:0: [sdb] No Caching mode page found
[ 2142.082772] sd 6:0:0:0: [sdb] Assuming drive cache: write through
[ 2142.087291] sd 6:0:0:0: [sdb] No Caching mode page found
[ 2142.087297] sd 6:0:0:0: [sdb] Assuming drive cache: write through
[ 2142.088563] sdb: sdb1
[ 2142.094264] sd 6:0:0:0: [sdb] No Caching mode page found
[ 2142.094269] sd 6:0:0:0: [sdb] Assuming drive cache: write through
[ 2142.094273] sd 6:0:0:0: [sdb] Attached SCSI removable disk
[ 2142.306854] FAT-fs (sdb1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 2476.019001] usb 2-1.4: USB disconnect, device number 6
[ 2496.521483] usb 2-1.4: new high-speed USB device number 7 using ehci-pci
[ 2496.618262] usb 2-1.4: New USB device found, idVendor=05e3, idProduct=0727
[ 2496.618269] usb 2-1.4: New USB device strings: Mfr=3, Product=4, SerialNumber=2
[ 2496.618274] usb 2-1.4: Product: USB Storage
[ 2496.618277] usb 2-1.4: Manufacturer: Generic
[ 2496.618281] usb 2-1.4: SerialNumber: 000000000207
[ 2496.619169] usb-storage 2-1.4:1.0: USB Mass Storage device detected
[ 2496.619284] scsi7 : usb-storage 2-1.4:1.0
[ 2497.619013] scsi 7:0:0:0: Direct-Access Generic STORAGE DEVICE 0207 PQ: 0 ANSI: 0
[ 2497.619510] sd 7:0:0:0: Attached scsi generic sg2 type 0
[ 2497.731972] sd 7:0:0:0: [sdb] 30703616 512-byte logical blocks: (15.7 GB/14.6 GiB)
[ 2497.733388] sd 7:0:0:0: [sdb] Write Protect is on
[ 2497.733421] sd 7:0:0:0: [sdb] Mode Sense: 0b 00 80 08
[ 2497.735017] sd 7:0:0:0: [sdb] No Caching mode page found
[ 2497.735025] sd 7:0:0:0: [sdb] Assuming drive cache: write through
[ 2497.740017] sd 7:0:0:0: [sdb] No Caching mode page found
[ 2497.740024] sd 7:0:0:0: [sdb] Assuming drive cache: write through
[ 2497.741351] sdb: sdb1
[ 2497.745571] sd 7:0:0:0: [sdb] No Caching mode page found
[ 2497.745574] sd 7:0:0:0: [sdb] Assuming drive cache: write through
[ 2497.745576] sd 7:0:0:0: [sdb] Attached SCSI removable disk
Cant anyone make a video........this process is VERY confusing
[ 3640.847515] sd 11:0:0:0: [sdb] 30703616 512-byte logical blocks: (15.7 GB/14.6 GiB)
[ 3640.848841] sd 11:0:0:0: [sdb] Write Protect is on
[ 3640.848848] sd 11:0:0:0: [sdb] Mode Sense: 0b 00 80 08
[ 3640.850283] sd 11:0:0:0: [sdb] No Caching mode page found
[ 3640.850289] sd 11:0:0:0: [sdb] Assuming drive cache: write through
[ 3640.855021] sd 11:0:0:0: [sdb] No Caching mode page found
[ 3640.855027] sd 11:0:0:0: [sdb] Assuming drive cache: write through
[ 3640.856272] sdb: sdb1
[ 3640.860511] sd 11:0:0:0: [sdb] No Caching mode page found
[ 3640.860517] sd 11:0:0:0: [sdb] Assuming drive cache: write through
[ 3640.860522] sd 11:0:0:0: [sdb] Attached SCSI removable disk
[ 3945.655983] systemd-hostnamed[4233]: Warning: nss-myhostname is not installed. Changing the local hostname might make it unresolveable. Please install nss-myhostname!
mint@mint ~ $
so the next step would be....
sudo dd if=/<path_to_debrick.img> of=/dev/sdX
sudo dd if=/home/mint/Desktop of=/dev/sdb
right?? I have mine on my desktop...that is where the zip is located
PLEASE.........this is driving me absolutely bonkers and I have been at it for 2 hrs
image is on the sd card......battery and sd card are inserted. Nothing happens......I am assuming the battery is dead? It was at like 40-50% lastnight when this all happen. Does the battery have to be fully charged in order for this to work?
which image did you write to the sdcard? did you end uyp going the windows route? did it write it correctly? any errors? did you use linux? did you just copy and paste teh image onto the sdcard? were you on 4.3 or 4.4?
need a bit more info.
i used the windows method.....i was on 4.3. I did not have any errors. I checked the SD card and there is an image on the SD card
used the win32 method.
1. downloaded win32imagewriter
2. installed the image by selecting the image and then the SD card
3. placed image on SD card (said successful)
4. removed SD from reader and placed into phone
5. placed battery in and attempted recovery mode.
The image I used was the one from post 1 for those who had 4.3 or higher
PNY 16G class 10
should i try the other image instead of the one I already tried??
im still completely dead........nothing is happening. Do I need a different SD card? Do I need to do anything to the SD card at all OR can I just take it from the package and it is good to go?
EDIT- just went out and got a new SD card......got a sandisk and same issue....nothing happens at all
EDIT 2- just junked the phone since I couldn't fix it
I've gone and done it. Flashed a Rom for the note, and the thing is DOA. Windows got installed the Qualcom device driver once, but it disconnected and The writing program won't even allow me to select and device. The phone won't power on at all. Im guessing sd reader, or buy a replacment. I have the SPH-710t. Thanks.
Still haven't got my SPH-L710t up and running after installing the Conquest Singularity Rom with Philz touch. I've tried the SDCard image method in Linux and with Win32imgloader in windows. I've brought a Jib now that isn't doing a thing to the brick that was made four days out of the box. The computer dose still see the phone as Qualcom both in Linux and in windows, but Odin and One Touch Unbrick won't recognize it. Can Android SDK tools and debugging that why help? Will it even be recognized? Thanks For all your help. Enjoy the weekend.
