Root [Boost Mobile] Huge problem need help FAST!!!!!
junior437
Member
hi ,(sorry for my bad English), iv bought my zte warp last week and iv rooted it yesterday but my ROM was lagy so decided to get it back to stuck then just root it but i forgot to make a backup before changing the ROM so i took the stock b07 rom from this site and now when my screen lock it com back with a black screen so i have to take of the batery and restart it (pretty annoying) ...now im trying to root it so i can change the rom because i know that my issue is from the rom itself but when i put my phone in usb debugin it chek the box but i dont see (the android spider that tell me that my phone is in usb debogin) and when i try to root it it wont reboot or instal cwm.... know i dont know what to do lol i dont whant to lose my 250$ spend on that phone ......Thanmks for helpin me quick i will make a donate if my problem can be solved
IM on stuck recovery not cwm and when i try to root its not workin ....if you want i dnd care to let somebody enter in my pc with a remote to try to root it
what i did is that i took b08 stock rom instead of b07 (i have a b07)i renamed it update.zip and i flashed it with the stuck recovery so i got usb dubugin to work again after i installed cwm with http://db.tt/orC2OItq from jetx2x (thank you by the way ! ) so i got my lockscreen workin again.....ty to all of you for helpin me out its hard to find people who work on zte warp and srry for my bad english ...
I had a similar problem seeing that you just bought it right it most likely came with bo8c being mine did and I bought it last year I through my trials and tribulations with attempting root I downgraded my from to bo6 and had that problem I had to battery pull to wake for a day at work but I wasn't rooted so I had to enter stock recovery and in a sticky for the ultimate warp drive I found the list of signed rooms bo6-bo8c I downloaded the stock bo8c from and flashed it through stock recovery and poof it functioned perfectly there was an issue with the camera having a severe blue tint but it solved itself I now have a backup stock bo8c on my laptop just in case I see you solved it but being you have the ability to root when you please (I have to go use my friends computer) it shouldn't be such a big problem next time just get a backup zip on your PC so you are well prepared for this next time
