Root [Boost Mobile] [Kernel] Glitch Kernel (2.6.35.7) OC. 1.8ghz
D
Deleted User
Guest
Team Osiris
And downthemachine present:
The Glitch Kernel
Based off hroarks original work​
Special thanks to Kroegs, Bocephus87 for donating! Thanks for your support!
I am not responsible for any damage you may do to your phone. This oc has been tested many many times, but going past stock levels could cause damage. You have been warned!
Questions are for the threads only. I will not respond to help questions in pm. All that information should be open discussion.
Now in two flavors
Non oc
And 1.7Ghz OC
Non OC​
The kernel everyone has been using on almost every rom
[B]Features:[/B]
Swap support
Ext2/3 support removed for more memory
Proper init.d startup
Ramzswap compatible, no script yet
*Added governors for more contol
Glitch Non OC v1.13
http://db.tt/FoUDM4dX
OverClocked:​
This is what everyone has been waiting for.
2.6.35.7 kernel Over locked to 1.7ghz
Stable, no loss of ril on wifi and no Bluetooth issues
Features
1.7ghz
Added governors
Swap support
Ext2/3 removed
I/O schedulers added
Glitch OC v1.2
Same as v1.1 literally no difference
Except includes default set to 1024
As a script. You can disable this script in init.d folder. Credits go to the makers of voltage control. User can define higher speeds with an app
1.7Ghz
http://db.tt/fj9LvJR9
1.4Ghz
http://db.tt/DPLxgDL2
Glitch OC v1.1
1.7Ghz
IO Schedulers
Simple(sio)
Deadline
bfq
VR
http://db.tt/HRr7uztq
Glitch kernel v1.0
1.6Ghz
No longer supported
This is only oc and swap
Installation instructions:
Make a backup!
Choose install zip in cwm
I would recommend you get an app like voltage control to set frequencies and io schedulers
Recommended apps:
These are the two I tried. I use CPU master pro. I haven't tried the free version. I wouldn't recommend setcpu for anything. I've had many issues with that app.
Free:
Voltage Control
https://play.google.com/store/apps/details?id=com.darekxan.voltagecontrol
Paid:
CPU Master Pro
https://play.google.com/store/apps/details?id=com.antutu.CpuMaster
*Special thanks goes out to Hroark13 for the hard work he put into making the original zte source usable. Also for consulting with me during the course of working on it. I'd also like to thank my testers. Without you, this would not be possible. And thanks for putting up with my 30 builds a night testing.
Kraziejedi
bhays3
Smoothkaos
Lilbit
And of course the members of team glitch
* is to be added soon
Look mommy, I'm gpl compliant. You should be too!
https://github.com/downthemachine/WARP_KERNEL_26357
if ya want to buy me a soda, coffee, etc to show your appreciation, I'm providing a donation link.
All donations go towards all things android and not for anything personal. Make sure you post your name at the end of that link so I know who to thank.
There is a known incompatibility issue with some build.prop modifications where wifi connects but doesn't have data. When I get time I will find the exact modification so it can be removed.
whitefiretiger found that this
video.accelerate.hw=1
In some build props causes issues with wifi. Thank you for the find!
There are also some issues with read ahead speed with oc. I am currently looking into this. Stay tuned
Results for read ahead.
I have found that different governors change the read ahead.
interactiveX gave me the best results for read ahead
Scary is a good balance of speed and read ahead
This is a good explanation of governors and schedulers. there are a million on xda,
but this is the one i picked
[REF][TWEAKS] Kernel Governors, Modules, I/O Schedulers, CPU Tweaks, AIO App Configs
Channel log:​
Coming soon:
V1.4
1.4ghz will get two more frequencies removed to match stock
Moving to 1.8Ghz top.
Memory and battery saving:
VDD controlV1.4
SLQB Memory Allocator
AVS
CLEARCACHE
KSM
memory compaction
Fudgeswap LMK
Zram & zcache.
Updated kvm.
Governors added, smoothass, lag free, brazilianwax, lazy, and lionheart
Init.rc edits credits go to Bloodawn
V1.3
Min max set by kernel
V1.2
Added a stock speed script
V1.1
OC up to 1.7Ghz
I/O schedulers bfq, deadline, vr and simple(sio)
Voltage changes for OC
V1.0
Added oc up to 1.6ghz
Retained swap and init.d from non oc
Removed ramzswap because of incompatibility
Testing 1.8ghz with less steps between. To see if we can ramp up and down with less time, and battery.
Also coming soon, a proper write up for the kernel along with explanations on governors and schedulers.
The Beta Test Zone​
*New: v1.4 test kernel
Freed up 10megs of real ram
http://db.tt/5jeEwsqu
V1.4 test build v3 rc1​
Clear dalvik and normal cache.
Lets just say, this one is way faster ;)
http://db.tt/3zOTiWpY
skipped V1.4 Beta 2
SLQB breaks wifi on this one​
V1.4 Beta 1​
Test build for anyone who wants to try the 1.8ghz. Includes some of the features listed as coming soon on version 1.4.
1.8ghz OverClock
http://db.tt/YTjq5zA5
OTG support beta
Don't know if it works, please test and report. If you don't know what otg is, avoid this
http://db.tt/mQgeFbqG
6 additional governors were pulled from the initial release for additional testing. That was one
Cool but im not running this one :) lol ill be keepin my eye out for the update. Also for the loss of cdma while on wifi fix. I look forward to your next one
Maybe ill flash it after i disable v6 and kak and see how it works
Edit- so it turns on fine and co nects with v6 its the kak that messes it up somehow. Leavin my wifi on to make sure i still have service after a while.
Edit2- i had to cut testing after my old friend sticky toggles came back. I only ever have the issue with them after turning wifi on but ill deal without wifi
About how much memory is freed up by removing ExtFS support? And does your OC kernel banish the typing lag that Hroark's had?
Honestly I can't tell you about hroarks kernel, it never worked for me. As far as the lag and issues with the other oc kernels it was improper voltages. Mind you this is just a start. I'm still testing new voltage and frequencies to get the best balance.
And as far as support for ext2/3, Hroark had told me that removing support for them may free up some memory. He had also said that support for them are not need with the warp
Ext2/3 are only needed if you plan on setting up a partition with 1 of them and even that can be done with ext4... though I wouldn't mind having btrfs support ;)
That's enabled to in the stock prop as well as yoshi and I don't have any wifi issues
Well I'm not seeing that in the stock prop
But the problem it was making was when you boot with wifi off when try to turn wifi on it would go "turning on" "turning off" wifi wouldn't work till reboot then would switch on off fine till reboot with wifi off then same thing again.
I removed that line and poof no more trouble
I dunno then... I'm running Yoshi with it on and haven't had any problems yet... but I've also only rebooted once since the update...
As far as it being on stock... it's on all the ones I have... though I have to admit it's possible they may not be all that stock lol ;)
Lol I've got the stock prop its not there. i use it for testing. If i suspect a prop tweak i switch to stock then if my issue goes away i work from there.
Whenever I want to test out new prop tweaks I'll either open a terminal or use adb and the setprop command... that way all I have to do is reboot my phone and it's gone.
Are we confirming a link? Or are we unsure about that prop setting?
