D
Deleted User
Guest
New beta build in post 4. Freed up 10 megs of ram. Needs to be thoroughly tested. Video, audio etc.
Flashlight wouldn't work in 1.4 latest beta, no other problem found yet.
There is any other app for flashlight that works on that kernel ?Sorry I keep forgetting to fix that!
Now I'm getting an playback failed errors when trying to play songs everything else is fine
Ive got the same issue. I didnt think to check onboard music until I read your post.
It has to do with the memory allocated to adsp. I was trying to trim the fat on alot of the pmem allocations to regain physical ram so the device would swap less, less swap, less lag.
I know frontswap/cleancache with a zcache backend help reduce this lag. The thing is, less swapping is always better.
hi. i m installed
Glitch OC v1.1
Glitch OC v1.2
but my governor is still same settings ,most adjust 1024 mhz .i want oc to 1500- 1600 mhz.there is not doc name as dload or i cant find that. pls help me.what can i do for overclock my device with my lovely rom. (2.3.7 russian rom+cwm+root)
my device= huawei u8850 vision.
thanks for all...
hi. i m installed
Glitch OC v1.1
Glitch OC v1.2
thanks for all...
