not a problem, yeah i got an image compiled last night finally but it wouldn't boot. not sure what I'm doing wrong here. trying again as we speak
CC arch/arm/mach-msm/acpuclock-7x30.o
arch/arm/mach-msm/clock-7x30.c: In function 'msm_clk_soc_init':
arch/arm/mach-msm/clock-7x30.c:1262: error: ri_list causes a section type conflict
make[1]: *** [arch/arm/mach-msm/clock-7x30.o] Error 1
make[1]: *** Waiting for unfinished jobs....
CC fs/ext4/balloc.o
CC net/ipv4/tcp_output.o
CC net/netfilter/nf_conntrack_extend.o
CC net/sched/sch_mq.o
CC drivers/input/touchscreen/SynaUpgrade.o
make[1]: *** wait: No child processes. Stop.
make: *** [arch/arm/mach-msm] Error 2
make: *** Waiting for unfinished jobs....
Stock kernel with the config, fromphone
Make ARCH=arm CROSS_COMPILE=$COMPILER -j 8
Gotcha. Your previous command line just had $COMPILER (only 1 "C") so that's what made me question if there was a typo in the command line. If you used $COMPILER in the kernel build command line, it probably didn't use the toolchain that you wanted to use. Maybe your previous post just had a typo too. I dunno. Just something to verify when building.downthemachine said:I have it set to $CCOMPILER I also have other toolchain set similarly like $CCOMPILER1 and so on
