Root [Boost Mobile] my new phone is going crazy
mac42
So got my replacement phone yesterday. Used noobvii for a fast root and recovery process. And when it went to reboot it froze during the boot animation. Pulled battery, reboot and it froze at the splash screen. So I rebooted in to recovery twrp was there so I flashed my latest backup which had alien kernel and shins rom. And got the same deal. And even froze at the unlock screen. And the I tried flashing my other backup glitch kernel and shins rom. And it works usually. I've tried flashing noob again a fresh dl of CT and shins rom and alien kernel. My friend lordvincent90 did a log at and said its not finding the keyboard directory or dictionary? When I used ctmod it would run until I started typing then it would just reboot.
How can I fix this?
I'm gonna try the Nan of bo8c and doing the flashing through cwm.
Any other suggestions.
This is really annoying
In this case, I would start from scratch.:) Complete wipe and start over, No Nandroids!!;)
Looks like you have suff lingering around from other roms and kernels and themes.:mad:
Well i tried the factory wipe/reset but that did absolutely nothing. The return to stock via cwm at least got me back to stock.
reDownloading noob, gonna try this again.
Probably in the morning cause its taking a long time to download.
Making sure i have the return to stock zip before i do this again too.
Set permissions? Can you explain? ?Fix permissions?
I have cwm. That went fine. And alien kernel went smooth. I tried to flash shijitsu and the same thing happens?
Im gonna dl ct, and the new cyanoid.
And format the sd :(
Im not even deodex'd :'(
Fix permissions. That was the magic.
Thank you everyone.
Earlymon. Your banned! :) for being in to many places
