Root [Boost Mobile] **n0ve THEME for WP7 ROM**
n0ve
Android Expert
THIS HAS NOT YET BEEN UPDATED FOR WP7ROM OC UPDATE, WILL BE BY 10 PM EST 5/21
For those of you like myself running WP7 Rom b/c you want to stick w. 08c, but are too lazy to make a UOT theme or just don't know how, I thought i'd upload the one i Just made, fairly simple, changed a font but its barely noticeable, added the glowing scrolling bar, custom status bar, icons, and bootanimation is a
simulated BIOS PC boot.
**UPDATED 5/12** as requested, removed n0ve in header ;\, made carrier opacity 0%, also changed notification's a bit to match the colors, changed popup to match colors, changed download bar/popupbar liner.
DOWNLOAD LINK:http://dl.dropbox.com/u/65761686/UOT-05-12-23-22-1.zip
(boot to CWM, whipe cache and dalvik cache just in case ( do not factory reset!) , install zip, choose zip from sd card, choose UOT-05-10-02-20-1)
(AFTER OF COURSE, DOWNLOADING THE ZIP, AND LOADING IT ONTO YOUR SD ;\)​
Nice theme! When i flash this will your name be on my notification bar or did you clear that? Also can you blank out the carrier info? Set opacity to zero maybe?
Ok, Im usually good with ROMing, and stuff like it. But Im stuck. Ive had the WP7 ROM so I thought I'd try out your theme. But after I applied it, it gave me my regulat options for WP7 or go launcher. WP7 looks the same other than the bars and icons up top. But it still looks like WP7. Do I use go launcher? Sorry if this is a dumb post but Im just stuck.
Thanks.
Thanks.
No worries...it seems like you may have done a factory reset/restored WP7 rom itself, when installing the theme, you don't do factory reset/erase data, you just clear cache, clear dalvik, and install zip from sd card....as far as launchers, the screenshots are from the launcher i use ftl launcher, but the theme itself only really changes, system font, notification bar, notification icons, window animations, glowing edges, and adds systembios animated bootscreen.
Yes i wanted to do that for myself, and ill update it later tonight and remove n0ve as a header and just put it in tiny fonts in the footer. Carrier info will be removed, and i made some other custom icons im going to try and put on there.
Bumping my own thread lol, anyone whos on WP7 rom and would like a different theme, I present you my updated version. (Some people have asked me inbox questions regarding their launcher, and its effect on it), UOT themes do not effect your Launcher, those settings are totally on their own...This theme replaces Icons (status bar), window animations, window glowing edges, bootanimation, lockscreen icons, Popup window, Download bar, Loading/waiting logo turned to Hourglass(Glowing).
I am using WP7 rom with this theme since yesterday...
rooted, SetCPU, GoLauncherEx, TitaniumBackup, ... 387 apps reported by TB
Everything working OK and this theme is very very very... good, excellent.
Thanks a lot
So its not really a problem but it had me concerned enough for a little minute last night that i started over but then waited it out....after i flashed this, it loaded the computer looking boot screen, then when it was building the android out of numbers and letters it got about half way through building that and then the screen goes black....after deciding i would be patient with it last night it did finally load, but it was weird to just have the screen go all black...like i said not really a problem cause it still works fine and everything, just wanted to know if it was made like that or what?
The boot animation is a simulated PC bios, and whenever youe whipe dalvik cache, which you must do prior to installing themes and such, it takes a long time for your phone to boot...the bootanimation was complete, but it was still rebuilding your Dalvik, therefore it takes a bit to boot, then every boot after that should be much faster, and if you do not like the bootanimation, send me a private message i have plenty to choose from i'll help you change it =0
Later tonight i will release an update for his new rom. If anyone has ideas/thoughts/ post them here so b4 i make a quick theme i can take anyone's concerns into play. I havent checked out the new wp7 rom yet so idk what it looks like and what people may be wanting.
