Root [Boost Mobile] [NANDROIDS] ZTE Warp GB. 2 versions.
Woodstock77
This is a nandroid backup for the ZTE Warp with only minor customizations.
Removed Boost zone and mobile ID.
Added: Custom boot animation w/sound.
Requirements: A rooted ZTE warp with CWM recovery installed.
How to install
  1. Unzip and copy the contents of ZTE Warp Nandroid RC1 to your SD card. In the clockworkmod/backup/ folder
  2. Reboot phone into CWM recovery.
  3. Go to wipe data and factory reset. Select yes
  4. Go to wipe cache. Select yes.
  5. OPTIONAL: Go to advanced. Select wipe dalvik cache. Select yes.
  6. Go to backup and restore. Select Restore. Choose 2012-01-27.08.04.07 and select yes.
Reboot phone and enjoy.
ZTE Warp Nandroid RC1.zip
Or go to post #32 posted by Lordvincent 90.
His link to the nandroid THIS
To install the Go launcher EX from SDcard
  1. Go to setting/applications/check Unknown Sources.
  2. Open DocsToGo app and after you accept the agreement and that crap choose local files and find the file named com.gau.go.launcherex-1.apk and select it. Choose install. Next time you hit the home button check remember this below then choose Go launcher.
New nandroid added 2-10-12
This is a nandroid backup for the ZTE Warp with a few major customizations.
Removed:
Boost zone
mobile ID
Default launcher with the mobile id junk in it
docs2go
And a few other things
XT9 keyboard
Added:
Rooted with CWM
Custom boot animation w/sound R2D2
Launcher2
Advanced task killer
A file explorer (for root);)
different images on taskbar with battery percentage and indicator
How to install
  1. Unzip and copy the contents of ZTE Warp Nandroid RC2 to your SD card. In the clockworkmod/backup/ folder
  6. Go to backup and restore. Select Restore. Choose 2012-02-11.09.59.19 and select yes.
ZTE Warp Nandroid RC2.zip
New nandroid added 3-4-12
N860_B08c_NANDROID
Removed:
Nothing at all
Added:
Rooted with CWM
How to install
  1. Unzip and copy the contents of N860_B08c_NANDROID.zip to your SD card. In the clockworkmod/backup/ folder
  6. Go to backup and restore. Select Restore. Choose 2012-03-04.14.50.29 and select yes.
http://www.mediafire.com/?iqw6vtgxwo6iuyi
:DDude your a beast at this stuff thanks alot for your hard work!!!!!:D
this is a nandroid backup for the zte warp with only minor customizations.
Removed boost zone and mobile id.
Requirements: A rooted zte warp with cwm recovery installed.
How to install
  1. unzip and copy the contents of zte warp nandroid rc1 to your sd card.
  2. reboot phone into cwm recovery.
  3. go to wipe data and factory reset. Select yes
  4. go to wipe cache. Select yes.
  5. optional: Go to advanced. Select wipe dalvik cache. Select yes.
  6. go to backup and restore. Select restore. Choose 2012-01-27.08.04.07 and select yes.
reboot phone and enjoy.
zte warp nandroid rc1.zip
to install the go launcher ex from sdcard
  1. go to setting/applications/check unknown sources.
  2. open docstogo app and after you accept the agreement and that crap choose local files and find the file named com.gau.go.launcherex-1.apk and select it. Choose install. Next time you hit the home button check remember this below then choose go launcher.
How to install
Wouldnt it be easier if you just put the file in a folder in your sd & go into cwm & theres gonna be a line that says "install zip from sd card"
& it will unzipp it & install it for you automatically
Edit : & then you just reboot
How long and the method of installation. The update.zip version can n be easily edited. nandroid version consists of disk images, update.zip version= installer + file structure. You can add delete add needed, where as nandroid format can not be accessed to add/delete easily
i need help plz zte warp rooted i have a black boot no sound i download and try to repllace but still dont work lol i del the stock one too lol
I got a zip file! I post it in a bit....Buying a warp today coming from the triumph! So lets see how this device plays out lol!
Hmm getting a updater script error
Dude I cant help you. Ive replied to at least 2 of your other post and told you what to do but I cannot do it for you. Sorry.
If this has nothing to do with my nandroid please make your own thread. thanks.
what is the error?
I dont know what to say anymore. :rolleyes: I know it has nothing to do with the OP of this thread.
i believe that he is trying to say he has and update.zip version of your nandroid backup, i too am working on it bit am having trouble getting it to mount the system correctly, it flashes fine but fails to copy the files to the specified directiory... this IS important because if you can get a 'stock.zip' working, then i can start making something custom... (ie- deodexed, zip aligned, some custom this and that, COMPLETE theming using uot... the list goes on) if this needs to be addressed in a different thread, one can be started, but i thought this was the thread for providing 'stock' recovery options, not just for peopleto say "hey, it restored, thanks!" over and over and over. i need some info to make more progress. you see i dont own yall's phone, my roommate does, so, for now, i can only use him for testing via email correspondence as we both travel for work and neither of us are in the same state now... if you are content with your phone as it is and can speak for your whole community i will leave well enough alone, im just trying to help advance the development of this phone to a point where i feel it is worth buying
starting to seem like a waste of my time, everytime i try to help or gather info, someone on here seems to have some snotty responce, or just have no interest in helping the people with enough knowlege to get things done.
EDIT- got test files to copy:D... just had to mount system manually...
But it DOES since im providing a update.zip from your nandroid??? Any im like poster above not worth the time since OP getting pissed about me posting on making a update.zip! Oh and i tested on brand new warp i got today and it works fine!
