Root [Boost Mobile] need help with stock B10 deodexed
slymike123
Member
I just downloaded MrBobo`s zip and rebooted into CWM recovery and I have two choices apply update from sdcard or install zip from sdcard. I think install zip is from when I rooted but not sure. I am new to this so I don`t want to make a mistake. Any help would be appreciated.
Install zip from sd-card. :D
Boot into recovery, CWM, scroll down to install zip from sd card,choose zip from sd card scroll to the file you want to flash.
  • Like
Reactions: Doc
When I click choose zip from sdcard E:Can`t mount /sdcard/ comes up
could it be the sdcard? should I try another one?
Ok, turn off the phone and pull the card, possible its a little dirty, But you may have to re format the card, use the phone to do it not your PC. Boot into recovery again,scroll to mounts and storage, scroll to format sd card. You will lose everything on the card doing this so make back ups of any data you want to keep. Re-download the file you want to flash to sd card.
Boot into recovery, choose install from sd card, choose zip from sd card, scroll to the file to flash and choose it, afterward, wipe both caches, reboot.
Thanks so much I will do that and let you know how it turns out.
Did what you said now getting this, Formatting /sdcard...
Error mounting /sdcard!
Skipping format...
Done.
Maybe I`ll try another sdcard.
Yep Yep .............;)
I put in another sdcard, downloaded the file again, checked on my files to see if it was there and it is, booted into recovery, went to install zip from sdcard ,choose zip from sdcard, but I don`t see the file. Here is a list of what I do see. Android/
DCIM/
GOLauncherEX/
GOSMS/
GoStore/
LOST.DIR/
Yahoo!/
data-app/
documents/
download/
factory.widgets.skins/
note_data/
EasyRootCWM.zip
Like I said this is all new to me, I`m I doing something wrong.Again thank you for all your help.
Just found it under documents, sorry all. It all went fine.
On another note, should I also download the B10 baseband zip. Again I am sorry.
Sorry if I did something wrong, just not sure how to go about things here. I`m new to rooting and flashing and all of this, trying to learn, so thank you for all your help.
