idk, i had a problem with the holo launcher and deleted it by mistake after i tried to reboot my phone it just stayed on the boot screen... i went into twrp and it said "no OS found do you want to reboot" tried rebooting and it just stayed on the boot screen.
once it is copied to your sd card, go to the wipe section of your recovery and wipe factory reset, system and cache. once those are wiped go to the install section of your recovery, select the noobVI zip in the list and swipe to install. when thats done, reboot and enjoy!
That happened to me, I found out the NAME of the rom was changed, because I downloaded and SAVED it twice, changing the name by one letter. Check and see if that has happened.
