yankees5963
Finally the first team ROM for the ZTE Warp!!!
We strive to make the most functional, most enjoyable, fastest ROM with the most amount of features. For this reason OTA updates will always go out because this ROM can always be improved.
Green not right for you? We will upload theme zip for a blue or pink alternative.
Before you tell us, in the settings menu the launcher settings force closes. this will be fixed as soon as possible. As well as some small theming changes. (OTA upgrade)
Changelog:
Any issues, report on https://web.groupme.com/#/groups/2712716 This will ensure a quick reply.
Now what you all have been waiting for!!
Under Construction
Wipe data,cache, and dalvin cache
Install the rom and reboot
If you choose to install non-oc, after installing the rom flash this:
Under Construction
Enjoy!
Changelog:
Installed apps: Boat Browser, Es File explorer, Titanium Backup, and OTA Upgrader
Redesigned Settings menu
OC Kernel (l.6gbs) with swap i/o configs and more
Init.d scrips
Zip aligned
Minimal apps
Green theme
Build.prop tweaks
Others (too late to remember)
Init.d scrips
Zip aligned
Minimal apps
Green theme
Build.prop tweaks
Under Construction
Under Construction
Enjoy!
