Yes you are right. Thanks to him.Thanx quietstorm, your Boot animation changer is what was used for the above email_restore zip![]()
Try this.Is there any reason as to why the commands through adb didn't work? If the adb method is useless (please inform me otherwise, because I would rather use this method than others), should I be installing the clockwork mod from here : (http://androidforums.com/warp-all-t...-7-beta2-warp-released-today.html#post3857981) to get started with the posted file above?
adb push email.apk /system/app
adb push email.odex /system/app
adb reboot
Try this.
It might no let you do that either.PHP:adb push email.apk /system/app adb push email.odex /system/app adb reboot
And yes that the clockworkmod to install.
it doesn't works....
The phone is rooted, with the WarpOEM1.42 ROM, but when I start the camera, the screen turn black and nothing happens. I must press the home button to return on my home page.
I've installed the email restore.zip with cwm, installed succefully, but not seems to works...
any idea ?
As it turns out, there's more than just one thing that can upset those fragile camera and camcorder apps. I think I figured out where I went wrong in 1.42 (and 1.41 for that matter) I just need some free time to execute the fix. Version 1.50 won't have this issue. Promise
