Root [Boost Mobile] request
junior437
Member
can someone do a rom witout the boost activation plz beacause im not with boost and evry time i reboot it restart my network settin ty
Are you referring to the app that comes up upon your first run of the new ROM which has you activate a Google account? I don't recall any app prompting you to set up an account with Boost, but I could be losing it. That has been known to happen.
Than you ...its because I'm with public mobile in Canada they release zte warp like 2 months ago because their phone where crap because they are on 3g
It was Not on my phone when I bought it but every from I use is for boost mobile and I'm not with them I'm wit public mobile and for activation with my career I got to dial *228 that's why I want to delete hand free activation because when its start I need to reactivate my phone with *228
I don't know if this will help or not...open /system/build.prop with a text editor and look for locale region. If this is set to US change it to CA I think for Canada.
If you did 1. Post a copy here on the forums so we can disect it and compare 2. Flash it back to your phone and let us know if the problem is still there. You may have to run through the activation once after flashing to stock...if so run through it and reboot to see if it continues
Its not a big prob ... I was in a hurry to get my phone rooted so I forgot to back up (stupid I know) and I'm pretty sure that the activation is in the rom ..
Contact me privately, I believe i can fix this for you.
*228 meaning....your running canadian carrier similar to vzw? ( needs to be unlocked )....
