mikegmoney
Hey wats up wit the whole superuser 3.1 after flash?i keep trying to update my binary and it keeps giving a fail saying that the su path cant be found or sumthing..
That was a great idea. I just set my phone to a static IP and it's doing okay on wireless now. Nothing needed to be done on the router except to check to make sure I didn't assign a duplicate address to any DHCP address the router might assign. To ensure the Wifi changes took affect properly, I restarted the phone which is some thing that should be done between each change to a Wifi connection if one is having problems with connecting like we've been having. That ensures caches, time-to-lives, and other network functions are cleared not only on the phone but to the other devices on the network like the router. At the same time I re-flashed the WiFi fix a second time and ran fix permissions. When I restarted the Wifi connected and has stayed connected. This is okay if I'm going to use my Wifi in only one location but not when travelling. It may, however, give those who are writing the code to make this work some insight into the problem. At least I hope it does.Has anyone tried out of curiousity, going to their router's configuration, designating a static ip for the phone, and setting that in wifi settings? it seems like if It is connecting to the router but not passing data, its a dhcp/dns issue that won't automatically assign ...curious if this simple change will do anything
tk
So this worked for you? and yeah you can do static ip without having to enter your router configuration but it could possibly lead to IP address conflicts if you don't reserve it...I do this at my home all the time but yeah when your on public wifi your going to have to switch back to auto...interesting that this worked for you but not others...I was talking to apollo last night...and like i said if it connects but doesnt let data pass the device just isnt getting passed thru dhcp correctly...I know apollo will fix this very shortly but I figured it couldnt hurt to try this, I'm going to try it myself tonight too..@Smoothkhaos this Did Not work for you? (make sure you pick an ip that your other computers aren't using...gateway depending on router brand switches from 192.168.0.1 to 192.168.1.0 sometimes....netmask is always 255.255.255.0 ... ) curious if this worked for anyone else..That was a great idea. I just set my phone to a static IP and it's doing okay on wireless now. Nothing needed to be done on the router except to check to make sure I didn't assign a duplicate address to any DHCP address the router might assign. To ensure the Wifi changes took affect properly, I restarted the phone which is some thing that should be done between each change to a Wifi connection if one is having problems with connecting like we've been having. That ensures caches, time-to-lives, and other network functions are cleared not only on the phone but to the other devices on the network like the router. At the same time I re-flashed the WiFi fix a second time and ran fix permissions. When I restarted the Wifi connected and has stayed connected. This is okay if I'm going to use my Wifi in only one location but not when travelling. It may, however, give those who are writing the code to make this work some insight into the problem. At least I hope it does.
Now I've found I've no root now. I tried to use TB and is won't work. Hmmmm
tk
i like the rom but the wifi and 3g dose not work and i used the links and it did not work can you help me
3g? i use 3g constantly wifi isnt working if you only use one wifi read the post by n0ve and set A static ip for the phone and you can connect as for your 3g problem what is happening i need to know a little more then "it doesnt work"
Cheers!
Can you turn on/off the 3G connection under the Mobile networks Data Enabled field in Wireless & Networks settings? That may help get functionality back.ok i will try n0ves post and for the 3g will it said i have signal but when i go to the market it says waiting for connection and the browser says cant open page![]()
Can you turn on/off the 3G connection under the Mobile networks Data Enabled field in Wireless & Networks settings? That may help get functionality back.![]()
Does that "ok" mean your 3G is ok now?
I know, I'm wondering if chris was able to overcome the 3G problem he was having.Usually just turning it off then back on refreshes it
thanks swiftkey3 for knowing what i was going to say haha ill update the OP to let new people know there is wifi problems
Just a heads up when i use the wifi fix my colors go all technoglow
if i patch the 7 no oc kernel the colors seems to be fine but no wifi again
my hairs falling out...haha just kidding i shaved my head(bad job with a crappy pair of clippers) but no really im just so worn out the ex decided to wake me up at 3 and 5 in the morning >:| ill try to get unitolgy Epsilon out either today or tonight at the latest tomorrow afternoon i have a few edits to do to the theme which ill do today
