HawgHunter
I have the stock apps from jetx2x on my sd card. He said they just needed to be copied into the /system/apps folder and the permissions changed to rw-r-r. I tried that with the stock browser file, browser.apk. I used the root explorer from your ROM and was unable to paste the file into /system/apps. Any ideas why? Thanks.
tk
Edit: It did the same thing for the stock email app. I believe the problem is that the folder is R/O and needs to be R/W. The file explorer on the browser didn't have any place to change it. I installed a copy of root explorer that I have since it allows one to change the read/write status. I was able to copy the files I wanted to move to /system/apps and after I restarted all of them showed in the app drawer. I feel a bit "duh" for even posting this in the first place but maybe it will help someone else.
tkEdit: It did the same thing for the stock email app. I believe the problem is that the folder is R/O and needs to be R/W. The file explorer on the browser didn't have any place to change it. I installed a copy of root explorer that I have since it allows one to change the read/write status. I was able to copy the files I wanted to move to /system/apps and after I restarted all of them showed in the app drawer. I feel a bit "duh" for even posting this in the first place but maybe it will help someone else.
