Root [Boost Mobile] [RM]StarScream-V2.0.1 [Developer Resource]
What Color should be Developed First
  • Red
    Votes: 25 33.8%
  • Blue
    Votes: 36 48.6%
  • Green
    Votes: 13 17.6%
  • Total voters
    74
  • Poll closed .
Its badass apollo..i like the way u theamed the red and silver...how do u get the red unitology wallpaper bak? Cuz when i used titanium back up i lost it...
Ill send it to you or post it here
Actually here ya go just save it
i followed ur instructions, now if the screen timesout/i lock it, it wont comeback on, the screen "turns on" and stays black, help plz
I just loaded this ROM and like the look. I was checking out system functions and had a problem when I went to choose a Wallpaper. Quickpic gave me an error and here it is: "Initialize JNI failed. Please re-install the app from the market." Did I boo boo?
I already had a backup so to install I wiped Dalvik and the cache partition. I also deleted user data/factory reset. Then I flashed stock B08 and restarted normally. Then I flashed Unitology and restarted normally. This is where I am now and the error occurred,.
apollo, do you know what's happening with this? Thanks.
:hmmmm:
I flashed the wifi fix and it shows connected but the IP address is unavailable in the Advanced section of Wifi settings. When trying to connect to the Play Store, it told me "no connection - retry". I waited a couple of minutes and retried. I got connected. I'll be testing more to see how stable it is. Thanks for this fix.
:)tk
