Ummmm, Houston we have a problem. It keeps force soft rebooting straight to the boot-ani. It comes to the lock screen and then when I unlock it goes right back to the boot-ani. Going to go into CWM, fix permissions, and reboot. If still doing it I'm going back to Epsilon until fixed.
Update: OK, pulled battery, went to cwm, fixed perms, still force reboot to boot ani. Gonna try to reflash Unitology after clearing cache/Dalvik again and if still doing it I'll go back to Epsilon.
I'm posting this for the benefit of newcomers who may have questions about the way to install Unitology v1.0a.
Here is what I did a couple of times to confirm that it works. I think you will have success installing Unitology v1.0a if you do the following. Important to remember is to clear the cache and Dalvik before flashing each time and to restart the phone normally between flashes.
Download the two files listed below and place them in the root folder on the sd card in the phone. Don't use files you may already have because the ones online may have been updated. Maybe not, but you can't be sure. Downloading them insures you have the most recent file without question.
Stock08B ROM:
https://www.dropbox.com/s/wz4ictcmqupo2xw/stockB08.zip
Unitology v1.0a:
https://www.dropbox.com/s/qdbhsorzyx43qul/UnitologyV1.0A.zip
I made sure I had good nandroid and Titanium Backup Pro backups; got myself a glass of water and a snack; then I took a deep breath and jumped in. Don't skip any steps.
* Boot phone into CMW recovery mode.
* Clear cache and Dalvik
* Flash the StockB08 ROM you just downloaded and put on the sd card.
* Boot phone normally until you reach the lock screen. No need to go further.
* Restart phone into CMW recovery mode. You'll have to hold volume up + power to get into recovery this time.
* Flash the Unitology v1.0a ROM you just downloaded and put on the sd card.
* Fix Permissions.
* Restart phone normally and you are in business.
* Update the QuickPic app from the market to avoid problems with some apps like the Camera and when choosing Wallpapers to name a couple.
Return to search this forum if you have questions. Ask if you can't find the answer after you search. Someone will be glad to help. They sure have been helpful to me.
Also, return to the original post of this thread to help the developer, apollostar2109. He's done a great job on this ROM and spent a lot of his volunteered time to make it happen. I'm sure he'd appreciate any size donation you can give him.
