nefcpainter119
Runs great man
Should I flash the stock 08b from your other thread before I flash Unitology? I flashed the 08bc when I installed jetx2x's Warp Cream Sandwich so I wonder if I should do the same here and flash 08b? Thanks.
FYI when I flashed b08 from the other thread then Unitology I had some crazy WiFi connection issues going on so do this (what I did to fix):
1. Clear cache and Install b08
2. Install NewKernel.zip
3. Fix permissions
4. Boot up and voila
If you still get WiFi ish let me know because I have other things that WILL fix
I'm gonna give this a shot, and take a break from my ROM. UOT kitchen pissed me off so I've been doing icons manually -.-;;
Manually...? I'd rather kill myself.... :screwy:
Sent from my N860 using Tapatalk 2 Beta-5
I sent my thing to UOT to cook at 5:40 EST. Here we are at 8:30 EST, and my files not done -.-; So methinks the kitchen hates me.
I haven't had any trouble with wifi so I haven't had to run this fix. Thanks for the info though.FYI when I flashed b08 from the other thread then Unitology I had some crazy WiFi connection issues going on so do this (what I did to fix):
3. Fix permissions
I wonder why you had to do this and I didn't. The only thing I can think of is that we didn't run the same stockB08 rom. This is the one I used: https://www.dropbox.com/s/wz4ictcmqupo2xw/stockB08.zip. Which did you use? Do you have any ideas why? I'm really curious? Thanks.
which link?the link is not working for me says it was deleted or moved
This stockB08 that I used: https://www.dropbox.com/s/wz4ictcmqupo2xw/stockB08.zip. The Unitology v1.0a is on the OP.What files are needed to be downloaded...? I have the B08 that apollo made...or do i need the newkernel.zip.?
I haven't had any trouble with wifi so I haven't had to run this fix. Thanks for the info though.I wonder why you had to do this and I didn't. The only thing I can think of is that we didn't run the same stockB08 rom. This is the one I used: https://www.dropbox.com/s/wz4ictcmqupo2xw/stockB08.zip. Which did you use? Do you have any ideas why? I'm really curious? Thanks.
