Root [Boost Mobile] [RM]StarScream-V2.0.1 [Developer Resource]
What Color should be Developed First
  • Red
    Votes: 25 33.8%
  • Blue
    Votes: 36 48.6%
  • Green
    Votes: 13 17.6%
  • Total voters
    74
  • Poll closed .
Hey thanks hawghunter, worked like a charm.
Hey danzo sorry i didnt get back to you im glad that worked it seems theres a quirk with updating ill have that fixed in the next version and galaxyesm thats wierd that your unable to update ill think of something to fix maybe try reinstalling the ROM from a stock B08
Was about to do that...but for some weird reason i was just messing around with market then i got out of it...and it updated by it self. :b problem solved idk why but thanks. (:
Has anyone else run into the problem I'm having with the pattern lock screen not working? I can connect just two dots and it opens but I set a four position pattern. I found out that any pattern will open it. What am I doing wrong? :confused: :hmmmm:
Edit: After apollo confirmed that it should be working, I went into setting and could not get it working properly until I disabled screen unlock security, confirmed there was no lock by trying to lock the screen and I just got the standard slider to open. Then I applied a pattern lock and it works okay now. Whew, I'm glad it's alright and it was just operator error. :)
Hmm ill look into that and im glad to hear it updated galaxyesm
This Rom is SIC!!!. Just trying to be careful with it so it doesn't boot loop, I think you have to leave the busybox alone, because everytime I updated the busy box it boot looped so, I hope that is the cause of it, if a dev. wants to look into it.
When i get a chance i will :D and hawghunter i think thats on your end i just tried and it worked perfect
One question...is there away to dont make the wallpaper move like when u chane into another "page" or "when moving the screen to another" ? Lol
Try long pressing the home screen and choosing preferences from the menu. From there choose Appearance and set Static Wallpaper. See if that works for you.
It didnt work guys >.<
Hmmm,
I know it doesn't help you, but I can swap between static and moving with ease. I just don't know why it doesn't work for on your phone. If it were my phone, I think I'd restart it and see what happens. I really wish I could help more. :confused:
Then here theres nothing cuz it moves..>.<
Yeah... turn the static scroll on... or off... forgot which is which
Sent from my N860 using Tapatalk 2 Beta-5
