StarScream2109
Extreme Android User
Thats a newer pic of that
Haha where did it confuse you? I just edited the icons still trying to get the check mark color to change
I was editing the layout so it would have sub category headers like in ics... confused the crap outa me
Sent from my N860 using Tapatalk 2 Beta-5
Haha i bet once i get a friggin laptop ill be adding a crapload of different things eventually i might go red honeycomb with it
Good luck with that... lol... I'm taking a break today... head still kinda hurts
it's a little....crashy. the last edition worked far more seemless. I go to use pretty much anything, it lags' out. then goes to splash screen. then goes into this weird state. all the lights are off but it won't turn on >.>
thanks sir.Well after completely wiping out every iota of my information on my phone (yes I nandroid(ed)) I have come back to report a 100% success on the ROM flashthanks sir.
i lied. something is conflicting with one of, or the mass volume of my apps. I installed all my apps and *plane crashing noises and hand motions* it does the same thing. sorry to wreck your day. hope it was peaceful. xD
I haven't had the problem that y'all are having so I can't contribute much besides ideas. Whenever I've come across puzzles like yours I try to start thinking outside the box. While trying to do that about your problem, it came to mind to ask what happened when you used the little hard reset button under the cover above the camera before using CWM to clear everything, flash stock, clear, flash 1.5? Thanks for helping me understand what's been done.
They say facebook is bad around here. But he indeed does. I stalk it daily.![]()
woa.......delicious.
