StarScream2109
Extreme Android User
So decided i have some stock apps im going to mess around with the stock ones and make them themed too
so when you guys want maps back in itll be themed and what not
Thanks for the quick reply, just wondering is there way to put a customizable power control widget in the pull down notification menu. Not trying to compare roms I have my old OG Droid, with the PE rom, that had that option. Just wondering.
i was pretty stable on epsilon but when i flashed 1.0a thats when the issue started.
i have done a reflashed
Okay it seems something in the build.prop may he causing instabilty please be patient as im working day and night on V1.0B i messed up last night and lost 3/4 of what i did
no problem as alwasy dont' get me wrong i am still using the rom![]()
Apollostar, you are doing a very good job, I love this ROM, and can't wait for the next, I even found a red themed Swype keyboard that makes it even hotter. Thank you! I will be Paypalling you this week.
Here some new screenies
Please do NOT call that number or i will have my head chewed off
Its something we all want but it has not been ported yet i will be including it when we get it as for the reboots im sorry the only thing i can suggest is try a reflash
Dudeee how did you get beats on your phn?![]()
From this... http://androidforums.com/showthread.php?t=579444
Sent from my N860 using Tapatalk 2 Beta-5
Thankksss dudeeee![]()
No problem
Is it like a music player?
