Root [Boost Mobile] [RM]StarScream-V2.0.1 [Developer Resource]
What Color should be Developed First
  • Red
    Votes: 25 33.8%
  • Blue
    Votes: 36 48.6%
  • Green
    Votes: 13 17.6%
  • Total voters
    74
  • Poll closed .
At one point I thought it had turned itself off but it came back on. I'm at the initial startup screen in Unitology 1.0B so more info will follow.....
FYI A little thing I've learned when waiting, if you hold your phone completely vertical and look straight down to the bottom of the screen and look between the glass and the black cover screen where your 4 buttons are, you'll see the slight glow of your screen indicating its still on and running. Stupid that I know this but hey, anyway to help my fellow ROM installing brethren! Haha
From what i read, it makes phone run smoother along with v6 script. At least the launcher runs smoother.
I just realized that unless the clear partition cache clears dalviks i have cleared them once since i changed from b08c to b08 or to unitology v1.0a or unitology v 1.0b but i havnt had any issues running anything
I love it i havnt had one issue reboot or force close from it im lookin forword to sein what you got next up
And i didnt find a custom notification that was more than just icons
Just go ahead and send me a text when you need a tester for it and can you check the v6 in rom toolbox or only that app? For future refrence. Im not too worried about the notification thing i just thought it could be cool to mess around with
Its probably in the xml files somewhere maybe when i get a laptop ill look into it
And i forgot to comment bout the bat life it seems way better and paifd with bomb that task set to kill imediatly on screen sleep its extended it hours longer than i was getting before
