StarScream2109
Extreme Android User
Well im glad to hear that
Thought id share the new google search and Facebook widgets
Try using bomb that task i think it works great but if you havebit turn off settings when it kills processes you will go back to stock ringtone
Just so everyone knows my experience with the new version, yerderday it was perfect untill I fixed permissions, then the rebooting started, but I rewiped cache and dalvik and reflashed the rom, WITHOUT fixing permissions and voila. Runs perfect. Hopefully you guys and try that until the next update
Curious... for what reason did you fix permissions?Just so everyone knows my experience with the new version, yerderday it was perfect untill I fixed permissions, then the rebooting started, but I rewiped cache and dalvik and reflashed the rom, WITHOUT fixing permissions and voila. Runs perfect. Hopefully you guys and try that until the next update
okay so heres some added specs for V1.0B
1)settings categories
2)custom splash image
3)debranded
4)loopy smoothness&V6 supercharger
5)sd card read speed increase
6)system and ui tweaks
and possibly more
Thanks for clarifying why you ran it. I always do what you do and run fix permissions right after I flash a rom. It does make a lot of sense. I am sorry that you had trouble but I thank you for letting me know so I can avoid the problem.Only reason was I usuallly go right back to cwm after a new rom/update ect and fix permissions just in case so I don't have to do it later. and yesterday I had forgot and had the new version for a couple of hours before I had done it. So after I did, I was mad at myself, But like I said it's all good now.![]()
Thanks for clarifying why you ran it. I always do what you do and run fix permissions right after I flash a rom. It does make a lot of sense. I am sorry that you had trouble but I thank you for letting me know so I can avoid the problem.![]()
Apollo just wondering if its easy to switch the splash screen manually? I heard you were going to change it to something else. Not trying to complain, wanted to keep the phone rated G as much as possible for reasons. (Great work by the way.)
Thatd be cool i like the sony look i use to have their first phone it wasnt bad
has any one had a problem wit restarts i have gone from none on the stock deodexed b08c
to two in two days just wondering if i am the only one
