Check it out, post #200 AND NO BOOTLOOPS!
I love it.
Btw u didnt include the holo launcher?
BTW You're @ 399 posts, next is 400!
On the serious side of RIG, I see it when I flash a rom and it says something like "Mounting RIG" and something else I can't remember. Just wondering what it meant.
I think you've fixed the problems. I am using wifi and 3g like it's supposed to be used and it's switching fine. I was able to install and start using Swype Beta keyboard. I think you've got it and I stand by my first post after the update was posted that this is a fantastic ROM. You've done a wonderful job and everyone should show their appreciation by buying you a cup of coffee by using the link on the OP. KUDOs to you!!!
happy to see that
ill keep adding to this ROM so keep hanging around
I have not tried it yet but I'll put it on my list at your recommendation. It will be hard to convince me to change from Swype Beta since I've become accustomed to dragging my finger all over the keyboard and still getting what I meant to type. Someone suggested I try Swiftkey 3 Trial and I did. It was also phenomenal at guessing what I meant to say. One six letter word I entered had all wrong characters and it still gave me what I meant to type. All of these on-screen keyboards are unbelievable when it comes to prediction. I am amazed but remember I'm from the era of the pencil and a dictionary.Hey Hawg, ever try FlexT9 keyboard? I LOVE it
Thanks for the suggestion. I'll give it a try.I have not tried it yet but I'll put it on my list at your recommendation. It will be hard to convince me to change from Swype Beta since I've become accustomed to dragging my finger all over the keyboard and still getting what I meant to type. Someone suggested I try Swiftkey 3 Trial and I did. It was also phenomenal at guessing what I meant to say. One six letter word I entered had all wrong characters and it still gave me what I meant to type. All of these on-screen keyboards are unbelievable when it comes to prediction. I am amazed but remember I'm from the era of the pencil and a dictionary.![]()
Clear the data of holo locker![]()
The bars change color when they are connected to Google's servers. Are you signed into an account and is auto sync enabled?there is only one problem... my signal bars are all greyed out and dont change, and 3g icon dosent do anything.. but i have net and service.. wat do i do?
I'm out of ideas except to go to cwm recovery and try clearing caches, clearing dalvik and fixing permissions. Just rebooting might fix it. Sorry I can't put my finger on a cause but I've not encountered the problem when making sure sync was setup correctly didn't fix it. I'll keep my thinking cap on.yep.i checked everything.im not too worried bout the3g animation.but the signal bars being as if i had no service bothers me..
