TnTKILLZONE
It had just about the same for me. Most of the freezes occur when I try to use the camera, when I use the "kik messenger" app, or when I use the web browser.
Miscalibrated battery. Happens on all roms, stock or aosp, if you don't run calibration after flashing.
EDIT: Another problem is every time I restart the phone the battery percentage jumps up and down. For example I'll charge to 100% and when I reboot it'll be at 92%, then I'd reboot again and it's back to 100%. Or earlier I was at 4% and i rebooted and it went to 15%.
How does one run calibration?
There's an app called battery calibration on the play store, just open it once and follow the instructions given in the app
yeah,but the app makes it easier by telling you your voltage so you can get closer to 4200 (which is a true full battery)
