Yes I tried using volume plus but im trying to replicate it on another rom and it doesnt seen to have any effect
Okay I will try that when I get home, at work now, I will gladly update you and thank you for your help!
 like i promised
Damn finally got 1.3 where its blazin now your gonna hit me with 1.4. OH ALRIGHT!
added to All thing root guidelike i promised
Well its still about a week out..lol. what mods have you made? Oc?
	No Oc yet but...
Added Xperia Arc 4 corners script, superphone lll works well with rom lightening fast, new boot anim and sum other stuff lol
Well, let me start by saying I am new at this. I rooted a few months ago to use Ad Free and Titanium backup, but have had nothing but problems with random freezing and rebooting during calls, etc. Studied the forums and tried some new things successfully... This is the first ROM I have tried, and I love it! Fast, slick, clean! Thank you! I have so far, in a week, only noticed one real bug... I have no notification of voicemail. Now, this may be a compatibility issue, because I don't understand how all this works. Should I have updated to B08C before flashing the ROM? Phone still says B01 but shows Icon ROM... If I need to update, do I need to re-install the ROM after? If so, is there a way to avoid re-downloading and installing apps again? And an off topic question... with gmail sync on, it imported 1800 contacts - every email I have ever had became a contact! Where did I go wrong? But besides these very few questions, I really like this ROM. I have only had 2 random reboots in a week... I was considering setting up swap, but it looks like it isn't supported in this kernel? I'm thinking the lags and freezes may be RAM related? Being new to this, I'm not sure how to move that direction with this ROM... but once again, a big thank you to mhannah and I eagerly await the next update!
Another round of props, even on the wrong build - this ROM is slick. Much more fast and reliable than stock. True, the problems I am having shouldn't have anything to do with your ROM. And the only one that could be ROM related is the voicemail notification issue... But once I upgrade to B08C it will probably disappear... I am going to wait for your update, then upgrade before flashing your ROM. Last time, I followed your directions - reset, wipe, etc. I had absolutely no problems following your instructions. Thanks! So, before I try your new version, should I use Titanium to back up apps (but not system) so I can reinstall after? Then upgrade at ZTE's website to B08C? Then reflash ROM, then reinstall apps with titanium? Thanks again!
excellent work on this rom. can't wait for 1.0.4
Thanks, 1.0.4 should be out by tommorow evening
Kernel, Swap or OC in this update?
i have tried about 5 diff roms and i keep going back to iconrom really like this rom cant wait for update how do you install a update if i am running iconrom
.......... Thanks! So, before I try your new version, should I use Titanium to back up apps (but not system) so I can reinstall after?.............. Then reflash ROM, then reinstall apps with titanium? Thanks again!
