Root [Boost Mobile] [ROM] ICON rom V2.0 * released 10/16/12 *
Great Rom mhannah3333
I personally like the fact that my ZTE Warp is Overclocked up to 1.7ghz =)
Changes I made to your ROM:
-INSTALL Root App Delete (uninstaller)
-CHANGE fonts to STOCK using FONT INSTALLER (Overall everything looks better)
-REMOVE Adfree and INSTALL AdAway (Much better + had a problem with Adfree and my Gmail account not loading images)
-REMOVE gallery and INSTALL QuickPic (You should use this instead)
-REMOVE keyboard and INSTALL Smart Keyboard Pro (Keyboard was too small)
-REMOVE Google chrome port and INSTALL Dolphin Browser (Much Better, in my opinion)
-REMOVE Boat browser and INSTALL Opera Mobile (Much Better)
Suggestion: It would be more eye-catching if you can change the POPUP VOLUME BAR to a different COLOR instead of GREY.
Thanks and keep up the great work!!
Add screenshot too!!!
Screenshot has been added as a flashable addon. You'll find it in the add-ons section of the op
My apalogy for calling you Sir i did not know you were a woman also sorry to read about your phone hope you wont go away your talent and hard work is appreciated.Thanks again.
Since this rom will no longer be updated by mhannah unfortunatley, would a dev take on thhe updates for this rom. This rom is 1 of the best out there, the themeing far surpasses all other roms and I feel it deserves to be updated to B10 and beyond. Who will take it on?
If I still had the warp.. I would update this rom but unfortunately I don't, so if any device wants to take over this rom.... Feel free
Best Rom sucks there isn't anybody to push to the next lv. I really need wifi tethering I can't seem to get it to work if anybody can point out a good app or a link I would greatly appreciate it Thanks in advance
:smokingsomb:
:smokingsomb:
Barnacle usually gives good results :)
