mhannah3333
Thank you. Im glad your enjoying it.
whats the difference between the signal bars being blue or green on you ROM? for some reason they are always switching from blue to green even when standing in the same spot and data seem slow when they are blue.
The signal bars turn blue at full signal. You should have better 3g when they are blue. They only turn blue on the fourth bar. They go red at one bar.. orange at two, green at three and only blue at four. If you notice the bars aren't all the way to the top ;your not connected to Google play services
Edit: as far as them changing while standing in the same spot that's either network congestion or your phones' tower hopping.
hhm ok.....well im back on your rom and im very happy! I think you have some of the best theme work on any rom. got my IO and governors all set the way I want them running 4016 at 1.4ghz sio/smartassv2. Thank you as always, love your work![]()
Thanks..konceptz. you'll be even happier with 2.0 when it comes out next week. Would you like to test for me in a few days.. maybe sooner?
......just PM when your ready:thumb:absolutely.....Call me Eddie......just PM when your ready:thumb:
Alright Eddie...will do
Btw.. your avatar gives me the creeps..lol
WHOA!! Now that looks HOTT!!!! Lol! Don't forget me as a tester!!
EDIT: Mhannah3333 did you notice that the 1 digit is different then the other digits on the themed dialer?? Just wanted to let you know about that...
Which one?
The number 1 is bolder than all the others. Maybe because there is less text on that one? Don't know, I kinda like it though.
This rom ROCKS dudette. You did a fantastic job. I really admire when someone pays so much attention to the small details, it really shows in the end product. You got a new fan dudette, Thanks for the hard work.![]()
New oc will have it preset within the kernel to have min and max frequencies match stock. So you will no longer have this issue
If I set the clock speed to a lower number would that make any difference in the issues that I've encountered?
I installed Beats audio driver,then uninstalled not Volume + keeps crashing how can i fix
