Root [Boost Mobile] [ROM][Linaro][Team Osiris][HYBRID]ParanoidAndroid 2.57.6 [Jellybean 4.1.2][UTACKA]For ZTE Warp
Dm47021
Android Expert
  • Based on Jellybean 4.1.2
  • ParanoidAndroid 2.57.6
  • Fully Source Compiled
  • Hybrid UI mode
PER-APP-COLOR,Paranoidandroids newest invention. Define apps in your regular hybrid panel (same that allows you to scale apps individually and choose their interface). See your phone fade into the color definition of your current app, press home or go elsewhere and it fades back. Create as many combinations you like, you can even dabble with opacity. This feature is made possible by our hybrid engine, which is unique to this rom.
To be honest, this is not tablet mode at all, it has nothing to do with silly build.prop hacks. This is the first and only Android rom to feature true Hybrid mode. This rom lets you scale and project every app, every widget, even systemcomponents individually. Remember, android is modular, everything is an app: Lockscreen, navigationbar, dialogs, popups, keyboards, widgets, and your regular apps of course. Apps have the capability to switch into various designs or layouts according to the device they run on. This can result in a complete new experience as many apps will transform to the better.
Now for every element that you like chose a mode (PhoneUI, Phablet/Nexus-7UI, TabletUI) and/or a size. You are 100% independent of the system DPI which runs nicely in whatever value it has been assigned to. You do not need to boot your phone into a certain DPI. Neither will most of the changes you apply require a reboot. You will not suffer from the myriads of troubles which normally haunt you under build.prop tablet mode. Your market, phone, etc. will all work, apps won't shrink on you unless you shrink them yourself. This project will entirely transform your device, but retain the aesthetics and the feel of your phone.
  1. NEW INSTALL
  2. Download Link:ParanoidAndroid_arthur-2.57.6-UTACKA
  3. Reboot Phone into CWM by pressing VOL- and POWER
  4. Flash the PararnoidAndroid zip file you downloaded in step 1
  5. DO A FULL WIPE.. E.G. FACTORY RESET
  6. Reboot
  7. THIS ROM MAY LOCK UP ON FIRST BOOT. JUST PULL BATTERY. AND YOUR GOOD. Not Something on my end
  8. Enjoy Paranoid Android By DM47021
  1. pa webpage: http://www.paranoid-rom.com/
  2. Go to Settings, System, Font size, set it to NORMAL
  3. Check "Auto Hide" in Settings, System, Statusbar, to finally get Fullscreen
Donations
While donations are not required to use this rom, they are much appreciated. but you are not obligated.
  • Switched to More Optimized, Lightweight Launcher2 from VanirAOSP
  • Switched to more Optimized LatinIME Keyboard
  • Linaro Bionic (LIbC) Optimizations for cortex-a8 (MSM8655)
  • Linaro Dalvik VM Optimizations for MSM8655
  • Transparent Notification Dropdown
I flashed factory reset cache dalvik then reboot system locks. Maybe a certain cpu setting perhaps not sure? UPDATE !!! i factory reset only and flashed rom and gapps and so far all my previous apps are auto downloading. Have not rebooted yet. Locked again
I wiped cache, davlik cache, super wipe, factory reset, flashed rom, flashed AOKP gapps, installed wifi, logged into play store, let it update. set cpu to 61 min,1708 max, ondemand, rebooted, and it LOCKED UP. AGAIN.....
yes thats what i did but then it locked up and i went back and dalvik and that seemed to do something but had cpu set 122 /1809 rebooted previously and it didnt boot. My workaround for now to boot is wipe dalvik
Perhaps I'm missing something... why would you do a factory reset after flashing?
I know, that's what's confusing the hell outa me! Is there a trick to making this one work? It looks cool as hell, just can't get it to come back after I load apps, set the cpu, or do nothing to it at all. I reboot, and it stops.
OK, here is what I've done so far, and so far no lock ups.
1. Flashed right over my AOKP Rom
2.Installed AOKP Gapps
3. Wiped cache and Davlik
4.Factory reset.
5.Reboot
locked up on first boot, pulled battery, then re booted.
Rom booted nicely, went thru all the logging in steps, and rebooted. Rom came back on. Set CPU to (61 min, 1708 Max, cfq, lionheart). Now updating Google Search and a few more and will reboot after they update. So far so good. I'll keep ya posted in next edit.
EDIT 9:07 P.M.:nOPE fROZE UP SOLID AFTER DOWNLOADING SOME APPS. Not sure if it doesn't like HangOut, or Talk, or Tapatalk. Or if it's just freezing up. Gonna try something different. I'm not giving up!!!
EDIT 9:40 P.M.: Did a complete wipe, and a clean flash, flashed gapps, factory reset, booted. login steps..... yada, yada.... let it up date, rebooted. FROZE......went into recovery, wiped Dalvik, rebooted. BACK ON! Now gonna try some apps again. Keep ya posted :)
EDT 10:00 P.M: will not stick, freezes up, and will not reboot. IDK.... IGU :( at least I still have my Good AOKP :)
