Root [Boost Mobile] [ROM][Linaro][Team Osiris][HYBRID]ParanoidAndroid 2.57.6 [Jellybean 4.1.2][UTACKA]For ZTE Warp
The warp is getting more support than the Blade! I can't believe it...
OK, here is what I've done so far, and so far no lock ups.
1. Flashed right over my AOKP Rom
2.Installed AOKP Gapps
3. Wiped cache and Davlik
4.Factory reset.
5.Reboot
locked up on first boot, pulled battery, then re booted.
Rom booted nicely, went thru all the logging in steps, and rebooted. Rom came back on. Set CPU to (61 min, 1708 Max, cfq, lionheart). Now updating Google Search and a few more and will reboot after they update. So far so good. I'll keep ya posted in next edit.
EDIT 9:07 P.M.:nOPE fROZE UP SOLID AFTER DOWNLOADING SOME APPS. Not sure if it doesn't like HangOut, or Talk, or Tapatalk. Or if it's just freezing up. Gonna try something different. I'm not giving up!!!
EDIT 9:40 P.M.: Did a complete wipe, and a clean flash, flashed gapps, factory reset, booted. login steps..... yada, yada.... let it up date, rebooted. FROZE......went into recovery, wiped Dalvik, rebooted. BACK ON! Now gonna try some apps again. Keep ya posted :)
EDT 10:00 P.M: will not stick, freezes up, and will not reboot. IDK.... IGU :( at least I still have my Good AOKP :)
I wonder if i uploaded the wrong zip .
what iam doing and havent had a lock up is
Processor:1868/61Mhz OnDemand/Smoothass/SmartassV2
iosched: Sio or CFQ
Memory Management:ZRam %18, Allow Purging of assets, Kernel Same Page Merging.
16-bit transparency
Surface improvement:Fix color banding (default)
and its running damn good :D idk what the deal is. i want to help
OK, did my normal routine:) Factory data reset, clear cache, clear dalvek cache. REPEAT!!:D Flash super wipe for warp:) Flash ROM and gapps with TWRP. Factory Data Reset Again.:eek: Now you can re-boot. Mine did perfectly:p
I have some apps downloaded, contacts synced, mail pushed through. Rebooted again, no prob:thumbup:
Setting speed and io scheduler, governer, Zram, etc, as per DM's instructions. Let's Rock!!!!!:cool:
how you guys like the launcher ?
Nice and light, are their any settings for it? :)
Got the mic issue, and no mms Dm, I will run
this for a few days like I did AOKP, seems super
fast right now though!! :D Me likes it:p
Did everything suggested was going well till downloaded google keyboard it didnt like that and froze and cant reboot. have to flash dalvik again but works everytime
Im wondering if it helps to full wipe and mount system data cache everything except sd card of course. Any one have the clockwork rec zip in orange?
what i mean is the brand name of our phone like my samsung captivate is captivatemtd. Im looking on CWM name for our phone to flash recovery
thanks dm . im trying to see if flashing reg cwm will do the trick for this rom. everything i do doesnt stick. Anyone have the orange recovery zip? I cant find it on here dropbox not found
Shouldn't matter what recovery program you use. ;) I am having the same issues, major lockups, freezing, and cant seem to re-boot:( Only by clearing dalvek or hitting the reset button several times works:mad:
Thank You LIL, I was beginning to think it was just me.
im trying to run scripts like infinity engine see if that helps and busybox
You might end up making it even more unstable. I only had one lockup using slim gapps though on this rom.
I agree, dont try to many Mods on your own, may make the Rom crash, and or, Brick the phone. :( I am using the slim gapps package as well. works great on everything so far, I can literally sync contacts and download apps immediately. :D
