Here I am, waiting for Dropbox to upload my file, so I figured I'd give a little info about things while I wait.
First off, thank you to everyone who's tried my ROM. There are tons of ROMs out there you could run, but you took the time to run mine. Thank you. This means a lot to me
Second, I changed the version numbering scheme for Warp OEM. Instead of doing build numbers, I'll be changing the version number now. I changed all the existing version numbers to reflect this.
Third, due to the large number of downloadable versions of Warp OEM there has been some understandable confusion among users as to what they should be downloading. I'll be updating the OP to clarify this, but I'll summarize it here. The stable builds are the main, current version of Warp OEM. If you'd like to try out my ROM, you should download the highest version number under this category. If you do so, and something fails miserably/crashes and burns/hangs/bootloops/forgets to do the dishes/gives you a cold/causes drowsiness, coughing, rash or sometimes even death (lol) or any other medical or non-medical mishap, then (
and only then - the debug builds are not meant to be "daily drivers") you should see what the highest debug build version is that you can successfully run. Whatever that number is, let me know and I'll see what I can do to help.
Fourth, in all versions of my ROM,
/data was not supposed to be being touched at all. Upon reviewing the updater-script, I think this might not have been the case. I guess these are the things you don't notice when you do your testing on your own device
In version 1.42 this issue should finally be fixed. Also fixed is the QuickPic closing issue, and the ads are removed from Root Browser. We also have some
build.prop tweaks added back in, so... yay!
Thanks again, everyone, and enjoy Warp OEM 1.42!
