wasn't shabbymod the first thing the prevail had after shabby and intrepth rooted that little beauty.... heres one for shabby, the first contributor for boost mobile android development![]()
lol![]()
I don't mean to interupt but I am running the Eclipse AOSP rom and got data working.
@ Shabby:
unbrick.img
Microsoft Windows [Version 6.2.9200]
(c) 2012 Microsoft Corporation. All rights reserved.
C:\adt-bundle-windows-x86_64-20130522\adt-bundle-windows-x86_64-20130522\sdk\pla
tform-tools>adb shell
root@android:/ # su
su
root@android:/ # dd if=/dev/block/mmcblk0 of=/sdcard/unbrick.img bs=1024 count=7
1680
card/unbrick.img bs=1024 count=71680 <
71680+0 records in
71680+0 records out
73400320 bytes transferred in 11.845 secs (6196734 bytes/sec)
root@android:/ #
if you dont mind, would you share how you put together this "debrick img" into a working whatever the end output is... i would like to have such knowledge![]()
guide will be up tomorrow
with aosp roms the reason you guys werent getting 4g before is you have a newer radio (ril) lib than what was in sprints builds, the cm guys must have updated to include a newer ril so you guys get it now![]()
BAM! I just tried The Kuban Updater theme changer for the 1st time and it worked. I am now running Wicked Sensations with the AnaKonda theme.
Here's a heads up fellas when changing the themes. Just go through the steps to install. When it reboots into recovery it will sit there and the progress bar will not move. At least it didn't for me. I actually thought I was gonna have to do a battery pull. GIVE IT TIME! It takes several minutes for it to flash the theme. DO NOT MESS WITH YOUR PHONE. After about 4 minutes it will reboot and your theme will be applied. PROFIT!
I'm usually a blue kinda guy but this AnaKonda theme isn't bad at all.
The main reason I made this post is because I didn't want any of you to make the mistake that I almost made and do a battery pull while in recovery. Sometimes that doesn't always end up very well. I was already getting ready in case I needed to flash TWRP with Odin. Lol. Thankfully patience prevailed.
@ Capn069, great news on the AOSP ROMS. Nice find bro.![]()
Should I do a full wipe before flashing theme! Or just dalvick cache and cache?
Thinkin about smoked out theme kinda reminds me of CT Mod on the prevail
Yes sir bro. I came very close to using that wallpaper too. Well, that was until the wife saw it and gave me THE LOOK. lol That was the end of that.![]()
I just haven't tested enough of them to start one. I'm working on it though.
I'm on the most ROM and my split screen works. Try toggling it in setting.
