wetbiker7
Extreme Android User
anyone?
As stated above, as long as the ROM contains a new kernel, the one you have at present will be replaced. Just make sure you follow the steps we've mentioned when flashing a new ROM.
1) Factory reset
2) Wipe cache
3) Wipe Dalvik cache
Do these things and you will be ready to flash.
Also, the MOAR ROM has several kernel options. I am running the Ktoonez kernel. When flashed, the kernel is not able to overclock. There is an app that comes with the kernel when choosen in the Aroma installer. It is called the KTweaker app. Open your app drawer and locate the app. Once opened you will see GENERAL at the top of the list. Open it and there you will see the option to enable overclocking for the kernel. If you choose to overclock, be very careful. Do not. I repeat, do not turn it up to the max all at once. Your phone will probably shutdown and then reboot. It will return to the default settings as long as you do not have the SET AT BOOT option selected. Also, when overclocking, always turn the kernel up slowly letting the phone run at a setting for a few minutes before turning it up again.
If you do decide to overclock, please be very careful. Overclocking improperly can do irreversible damage to your cpu.
Personally, I'm staying will the default kernel settings. This phone has plenty of power just running the Ktoonez kernel with its tweaks. No need to overclock IMO.
Good luck and prepare to be blown away with this ROM. I have flashed many a ROM and this is definitely one of the nicest I have ever seen. The options are numerous. It will take you DAYS to figure everything out. lol
