Lateralus138
Member
Hi all, I have used this and I got CWM and then Superuser installed, but then when I try to use the patch on CWM after it shutdwon to reboot then on my computer it says Unknown Device and your usb device was not recognized and it says the patch is transdered but the hangs at Rebooting... and just stays at the Android screen, I shut the phone down and restart then it detects it again correctly. I then retried to install the patch a couple of times with the exact same results. I have tested and do have root, but is there a manual way of installing the CWM patch?
Edit: Ok, I'm sorry I posted this prematurely. When it said "Before continuing make sure you're fully booted into Android" for the patch process I manually restarted my phone and left the cmd running and when it rebooted this time full I hit enter in the cmd and it completed successfully.
