Root [Boost Mobile] SD Card Recommendations
sb43
Android Expert
I was going to buy a class 10 64 gig card for my Warp, then after talking to someone I cancelled it. What class, and Manufacturer do you "Smart Guys" recommend. I have a plain old 32 gig card now.
What is the best class (6 or 10) for the warp as far as speed. I've been researching but all say they're the best!:confused:
Class 10 is the fastest.
Class 4 is the slow ones that most people have and normaly are included with devices.
I think the WARP only supports 32gb cards. But definitely get class 10, the read/write speeds will help performance.
Im running a class 10 8Gb PNY. Most people consider PNY to be off brand but I get amazing read speeds and the write speeds are always at least 9Mps
Good card, PNY is actually one of the majors, used to have a history of being way overpriced but they have reigned that in a bit.
class ten is the fastest. but class 6 is plenty fast if your not worried about true hd movies. the price difference would push me to class 10
