Ok
So I have been doing a lot of work on this phone the last couple of days and this is what my theory is
CWM Backs up and restore /data just fine
but there is some type of security feature on the Stock Rom that wipes your data partition on boot if it detects something
this does not happen on CM7, something else happens with CM7 on the newer phone
I think on newer phones there is a security feature that can tell your are not running the stock ROM, and once the screen goes off or you press the power button to turn off screen, it does not come back on
this does not seem to happen with other people, who have older phones that installed CM7
Now you know why ZTE is not providing working source code
this stuff is worse than CIQ
can any one who was able to run CM7 with out the screen issue use my partition dumper and provide me with all the partition except the big ones
system, data, and cache
http://androidforums.com/warp-all-things-root/521292-zte-warp-partiton-dumper-cwm.html
I want to compare the boot loaders on an older phone with the ones on my phone
thank you
thank you
