Root [Boost Mobile] shut down menu ?
ctislva
Member
i was wondering if there was a way to add reboot and recovery to the stock rom
in the shut down menu if somone could show me or post a nandroid with that menu in it i would like to know sorry if i put this in the wrong spot i wasn't sure
where to put it
where to put it
The stock ROM has to be deodexed in order to add this as for placing it in the right spot you did :D
Cheers!
ok i will how is your rom are there still bugs i am just waiting because i need my phone its my house phone too and i got three kids cant have it buggy if you know what i mean
No its all good just the wifi is goofey haha it connects but wont give you internet access that is the only problem
I will vouch for Apollo. Unitology is CLEAN. It is the best ROM you can have right now, unless you need WIFI. You will have no other problems with this ROM, but it is still in BETA testing.
is there any work around or something else i can do to make the second zip work with out having to flash the first zip, MR.Bobo?
