Ok i installed Volume+ 1.8.1 (found on market militia) and it worked great for increasing the low speaker volume on the warp. Enjoy.
You need root btw
You need root btw
First you must be rooted. Enable speaker modifications, volume at +10, eq on base boost, base enhance +6. Also make sure you are using volume+ version 1.8.1, earlier versions dont seem to work. Hope that helps.
