chevanlol360
Android Expert
This is a list of codes that Mrbobo and i have narrowed down from hundreds of various list. The ones below are codes that we have tested and can confirm that they worked.
Use these codes at YOUR OWN RISK!!! By using the codes, you understand that I nor Mrbobo are not liable for any or all consequences of the codes below.
Some of the codes below needs your MSL code.
Codes to launch various Factory Tests:
*983*7469# - various tests (no menu, it just starts testing, use the back button to go through them: screen, sd, audio loop test, speaker, vibrate, etc)
*#06# - Displays your Meid number
*983*0# - various tests (menu: battery, lcd, back light, vibrator, ringer, led, key, lcd off, sd, bt address, radio info, memory, touchpaint test, audioloop, camera, gps test, etc)
*983*07# - Various tests (menu: LCD, Ringer, Vibrator, Key Test, Audio Loop, etc)
*983*27274# - Phone reboot
*983*3640# - Phone info
*983*636# - Memory test
##33284# - Shows the cellular radio debug info, signal etc
##72786# - Changes DSA back to Factory "Close to a hand free activation"
Hit the thanks button on Mrbobo's post below
roduce Information[->"test" Menu]/Automatic Inspection/Factory data reset/Battery information)
