Root [Boost Mobile] Stuck in green android logo
The best I can do is go into download mode, so I cannot do anything that requires a USB connection. My computer recognizes the ZTE Handset Diagnostic Interface on com port. Someone please explain how I can flash a firmware image so that I may be able to boot the phone. The closest I've found on line was this for the ZTE blade:
[Guide] de-bricking a ZTE Blade - ZTE Blade / Libra ROMs & ROM customisation - MoDaCo
Is it possible to use CDMA tool or something similar? I would appreciate any help.
Pull battery then reinstall, volume down and power, then flash backup in cwm or download a rom on PC move to SD card, same pull bat. Then zip from cwm.
Can you boot into cwm?
I cannot do anything besides going into download mode. I need a solution at the download mode level. I've tried everything (battery pulled too many times already). I recall nOve had a similar problem, was he able to recover?
At the moment I cannot get USB to be recognized. I will work on it this weekend. When I try to boot it will not go past the green android, so I cannot do anything. I figure if the ZTE blade is recoverable in download mode, there must be a way to do it with the warp.
This all happened because I foolishly tried to flash ROM a friend of mine claimed would work on my warp.
Go into the zip file for that rom and see if there is a recovery.img . If there is, you might have a big issue then. If you flashed another phones recovery that is
You cant hold power and volume to get recovery on boot
No, it will not go into recovery. No matter what I try, it stays at the green logo. The only thing it allows me to do is go into download mode by pressing the + and - at the same time (middle) while pressing the power button. The link I provided shows a guide for flashing a ZTE Blade in this state, so I'm hopeful there is still a chance I can do the same somehow. I'm also working on getting USB to work somehow, but no luck so far.
Thanks everyone. I greatly appreciate your willingness to help out.
Guys this is same deal as mine..shot...i have some Samsung guys trying to make a compatible tar but i tried everything...best bet send to ZTE and pray lol
Hello,
Did anyone find a solution to that problem. I have the exact same problem. The only way the phone will go in some other state different than being stuck on the android logo is holidng VOL+ and VOL- and power. Then it will connect to my pc saying it is a diagnostic device.
Hello,
Not sure if it will work for you but you could try PDA.net
I don't think your phones bricked... Umm.. try holding power and volume up. If that doesn't work try n find snakex and use his method of returning to stock. His method only requires your phone to be recognized by your pc. Using his way you can maybe get your warp running.
The only way I was able to fix a phone with this issue was to switch the motherboard out with another warp with a broken screen.
Where can I find that method you're talking about?
