Root [Boost Mobile] SU Binary Update Error
Table83
I'm curious if anyone else is getting the binary update error? I'm kinda a n00b at this whole root thing. Is there an easy way to update it? I tried the SU Update Fixer and that actually failed miserably, and I had to redo the whole phone.
If There is not I will just leave it as it is. I'm really liking the simple features like backup and stuff.
Thanks
Thanks
We all get that error. I wish it was turned off by default but go to superuser app and hit menu then preferences. Scroll to the bottom and uncheck where it says outdated binary notification.
Hi everyone, I ran into another problem. OK I have root accessnow,yayyyyyyy! I wanted right away to see if I could put internet on another device(my old Galaxy prevail) Now wireless hotspot turns on and says I can share internet but my galaxy is not finding it. Now I had my neighbor come by and turn her hotspot on her phone and my galaxy connected to her phone. Why isn'tmy warp not being recognized? Superuser says I have access.
I'm also getting "su binary update" message using super user, I get failed every time soI read a forum bout installing the busy box installer from the market n which I did. its suppose to fix the update problem but I don't think it did cause I have no idea if this binary update is a part of why it won't let any devices find my warps WiFi connection. Oh her phone let's my prevail use her hotspot. . I use Google Wi-Fi for root users and it says tethering is running, Why won't my warp be recognized?
I read this on another post so i dont take no credit for it. I was having the same problem with su binary not updating. All you do is go to the superuser app uninstall. Dont worry it wont uninstall it just says it does. Then reopened superuser and went to preferences the Su binary and tap it to update and it did.
Nas is correct.... there have been several threads on this topic... Plz search next time :)... anyway you may also get an error about remount ting sd... that is normal... lastly... the binaries can be left alone and you can ignore the notifications through su settings.
