Root [Boost Mobile] Super_phone III build prop tweaks
I think the super build prop screwed up the market. I get a device not compatable when I try to get amazon mobile :(
Edit: I had to side load the apk for amazon mobile.
I don't think build prop would have anything to do with that,I am having no problems. The build prop tweaks effect the phones performance as in scrolling speed.as far as being compatible with apps that shouldn't change.
There are a few tweaks.that could set it off wrong in build.prop...like dpi for example...
Changed or added for,
Fast reboot
Increase video recording quality
Video acceleration and touch responsiveness
smoother phone
Increase performance
increasce VM heap size
Render UI with GPU
faster scrolling
photo and video quality
Apps load faster
Disable black screen issue after calls
deeper sleep for bat.
I think that's it.like the op says building off of chevranlol base.
Please anyone has problems please state,my intentions are all good.using on my phone and just wanna share.
Jet isn't available right now, but I'd ask him what lines in the build prop are for ota, I remember him saying there is three of them, all you would need to do is find them and copy them over to the new build prop.
If i already have v6 super charger script installed, will it makes a difference? Just wondering if they will clash running b08 if you can make a version for that. Can i run out hand and hand together
Just reinstall v6 and it will add what it needs to the new prop
Well I don't think its the build prop,I am having no problems
Is anyone running this build prop having any internet issues?please post.
Only trouble I have is switching between wifi and 3G. Always have to reboot. In Shin's thread there is a modified build.prop that fixed this issue. Some changes were made to the wifi lines. Let me find it in my drop box and I'll post a link for you to look at.
http://db.tt/jyvqDO7u
Updated op please redownload.
Pandora works
I heart works
Switching back and forth from wifi to 3g works
thank you guys for posting.
