Root [Boost Mobile] Super_phone III build prop tweaks
Same thing as before for me doesn't switch between the two without reboot required
I am sorry but might be another issue,as for now I only can go off of how my phone works and I can switch back and forth with no problem,I usually don't use my wifi but Sunday I was and had issue switching to wifi,but now I am good.we need more people to test and post .
And let us know how theirs are working cause I want to please all.
1st link has xloud lines added,not to sure if thats all you need for it,I havexloud installed,maybe someone can answer that question.
I had to go back to stock.
None of my internet radio apps would play. I use Slacker and TuneIn.
Have you read op? Internet radio fixed! Tune in works I just tested it,I used to use it and reinstalled with TB and works fine.
Download link and test again.thank you.
It wasn't ur build.prop... it was my crazy phone. I think I got too much going on with it
If you read through post as of now there ate no known issues with SUPER_PHONE ,How ever if you do run into something please post so I can test and correct.My goal is satisfaction. And maybe some devs to include this in their roms.thank you to all that did and going to download,FEED BACK IS IMPORTANT.
If u use bluetooth and try to cut on your wifi, wifi wont cut on. It will try and keep disconnecting, it might come on after a while, about a hour of trying, went back to stock.
