When i run the 3g turbo charger script i cant connect to the internet and lose. Reception.
There's no need to be rude. I've never heard 'cut on' to be slang for 'connect', either.
Running the noob rom switching back and forth works for me ,granted it switches little slow I think.
That's because it doesn't work for the warp
So superphone2 is working on WCS?
My Rom Is Base On Stock And The Issue Still Continues With Wifi and Bluetooth.
What rom are you using? Cause on noob I can honestly say super phone works great with wifi ,Bluetooth, both and switching back and forth. I am right now at the moment testing some 3g tweaks I added and so far all still works. With all that said almost anything could be causing wifi problems. This build prop is working on my phone perfectly.I turn on the wifi but it doesnt work i go on my fb app or instagram or anything i requires data doesnt connect.
I mean it switches perfect no doubt but when im wifi i cant connect to anything
I believe that this build prop and noob rom duo is the perfect combination!iknow this may be out of topic but when im truing to update my fb app it sayd its not compatible with the warp?
