Hello, I just want to know how you can flash this ROM onto ZTE Warp phone, and will it cause bootloop on device? I really want to use this new update right away, but I'm concerned as to how the process goes to install this ROM, as I am new to this.
there is a 3g fix for this. Install it and your all goodYes on boost. And I lost my 3g connection now. Running on WiFi only. This sucks
I just want to tell everyone thank you, I have used these forums for all my Androids. I actually Started with the Motorola I1 that was a nightmare phone. I have tried every rom at least once. So far this one is the best. I really hope the development doesn't stop. Thank you again
Well after some research...downloaded Chomp MMS....and reset apn settings to MMSC: http://mm.myboostmobile.comMMS Proxy: 68.28.31.7This Rom is GREAT.....has anyone gotten the MMS working?...have done the small gapps...and the 3g updated...everything else is cool...just can not send or receive MMS... I even have XBMC working on this phone with this rom...
its in the previous posts...around page 30?Hey Fellas, I was hoping someone could help me find the link to the "3G Fix Link" great CM ROM I just cant for the life of me get my 3G Data working. Thanks so much !!
my bad...page 62its in the previous posts...around page 30?
DM47021 Thank You for your Efforts Rom is Wonderful!! so far best one yet!!![]()
CyanogenMod is an open source replacement firmware for smart phones and tablet computers based on the Android mobile operating system. It offers features and options not found in the official firmware distributed by vendors of these devices.
Features supported by CyanogenMod include native theming support,[3] FLAC audio codec support, a large Access Point Name list, an OpenVPN client, an enhanced reboot menu, support for Wi-Fi, Bluetooth, and USB tethering, CPU overclocking and other performance enhancements, soft buttons and other "tablet tweaks", toggles in the notification pull-down (such as Wi-Fi, Bluetooth and GPS), app permissions management, as well as other interface enhancements. According to its developers, CyanogenMod does not contain spyware or bloatware.[4][5] CyanogenMod is also stated to increase performance and reliability compared with official firmware releases.[6]
CyanogenMod is developed as free and open source software based on the official releases of Android by Google, with added original and third-party code.
Here, We have built CM10 "Jellybean 4.1.2"
For the Zte Warp. its been a long time in the making since out LiquidSmooth release. Things are starting to come together though. There are still bugs, some things not fnctioning as they should, But i think you guys all know the situation by now.
This is PURE CyanogenMod, no Custom modifications to the system, except for those required by hardware
Current Stable Version, Beta 2
There are no more Milestone Releases.
This project has reached the point of Beta Quality, Which isnt bad at all
WHATS WORKING AS OF BETA 2
Camera, .. video recording is not working yet.
RIL / 3g
SMS
Phone calls
Wifi
Bluetooth
Speakerphone
Mic
Sensors
and other things
DOWNLOAD
Download BETA 2 HERE
CHANGELOG
BETA 2
Changes
Updated Kernel kgsl to ics choc, fixes lockups for the most part
Added Arm Cortex-a9 linaro strings to bionic VERY FAST
Camera Working
Bluetooth Working
Wifi Working as it should, no lock up
DHCP working, no more static ip
Fixed issue with settings no sticking
Apollo Fixed, doesnt FC the first time.
Eri / Netowork fixed, shows up as Boost Mobile
Fixed most of the issues with system stalling / freezing.
Kernel Updated
Switched to Frameworks Native from LegacyMod
Switched to Frameworks AV from LegacyMod
Webkit patched for smoothness
CM10 Milestone 7.1 08302013
Changes
Frameworks Changes:
Transparent notification shade
Triggering EarlySuspend based on BackLight brightnes
Allow purging of asset bitmaps... ported from Froyo
Optimize gradient textures
Fix memory corruption in LayerRenderer copyLayer
Plug memory leak that happens when reusing display
Fix texture corruption
Use RGB565 surface for wallpaper
Prefer 16bpp formats for opaque bitmaps
Settings Changes:
Enable the NAVBAR
Add Option to disable boot animation
Add Partition info option in settings
Reboot Menu Changes:
Add Hot Reboot option
Add bootloader option
Phone Changes:
Add option to exit to homescreen after call
Trebuchet Launcher Changes:
Fix icon label shadow outline rendering
Milestone 5:
"Nightly-07252013 and up"
Fixed Sensors (Screen Rotation, Accelerometer, Light Sensor & Proximity Sensor)
Fixes stability from M4
Mile& stone 4:
"Nightly-05212013 and up"
Audio Routing Fixed
Most Of The System / Apps Are Now Hardware Accelerated
APNs / MMS partialy fixed
New Kernel .went from 2.6.35.7 to 2.6.35.14
WiFi seems to be more stable
Added Hot Reboot Option to reboot menu
Added Bootloader Option to reboot menu
Ramdisk and permission Fixes
Fixed some lag issues.
Milestone 3:
Fixes some stabillity, Fc issues, Permission changes, Play store Working Better "Nightly-05162013 and up"
Milestone 2:
Fix USB Mass Storage "Nightly-05152013 and up"
Device Tree:
Overlay Changes for mounting of sdcard
Overlay changes for Power profile, Apns, Storage, and hardware
Complete Ramdisk Overhaul
Libhardware_legacy: Wifi.c fixed to load Wifi modules on boot
Build Libaudio from source, fix alsa audio
Switch to WPA Supplicant 8 from Ver 6, Networks are more stable.
Backport Libnetutils from cm10.1 to cm10 (better net performance)
Coded & added the WarpedParts app to calibrate sensors (when sensors are fixed)
Baseband is now seen by the rom..as it should be
Other misc tweaks / rewrites
Thanks
Hroark13, Downthemachine, Jetx2x, TattooedGod, Jssa28, Phenomx4, Dm47021
Dm47021 & Downthemachine did all of work to kernel and most to the device tree. We couldnt have done it without the other guys too
On that note, Dm4721 and Downthemachine..Never hated eachother, it was just a big publiclity stunt lol
Google Apps Package
DOWNLOAD: Download Here
Updated Google Apps Package
DOWNLOAD"Tigatron" UPDATED GAPPS PACKAGE
Donations
If you would like to buy be a beer, Jaegermeister, or just feel the urge to donate
DM47021
iF you would like to donate to the other guys, let me know... and ill get their links posted
ENJOY
Also Check out the Team Osiris Webiste Team Osiris Development
step 1 root ur phone
step 2 dl and install cwm or twrp
step 3 dl rom and gapps package
step 4 place rom and gapps on sd card
step 5 reboot phone to bootloader w vol down and power button till the android pops up
step 5 whipe cache/ dalvik cache under advanced settings then whipe data factory reset
step 6 chose install zip from sd and find were u put the rom flash it first then whipe cach and dalvik
step 7 find gapps and install it
step 8 whip cache/dalvik and data then reboot and enjoy
