Root [Boost Mobile] [THEME][n00b VII] BLUE-ME-AWAY (11/10/2012)
EDIT....installed VII while using ur theme and every thing stayed the same ...no issues.....dont think ill be changing this theme for a long time.
Will this theme work with NOOB VII as well? or will it need to be updated?
Sorry for the late response, this new update is not affecting the theme at all.
The only visible change that you'll see is the play store main icon,
if you want the "mean android shopping bag" back, just re-flash the theme and it will not make any other changes to the new update. ;)
EDIT....installed VII while using ur theme and every thing stayed the same ...no issues.....don't think ill be changing this theme for a long time.
Yeah, there will be no issues updating to VII, and about you using this theme for a long time... hum, don't know about that, I'm working on a new one that may change your mind :)
I flashed on top of NoNb VII update Now my power menu is gone. When I press power button it reboots, no recovery, screenshot, power off, ect. options at all. I have to do a battery pull and boot in recovery. I tryed fixing permissions, wiped dalvic, started over and reflashed everything and it did same thing. Any Ideas?:(
Don't know what to tell you bro, I had installed the Pink theme before the VII update.
I have updated to VII and after I 'd flashed the Blue theme just to test it but everything looks OK on my phone.
See if you can clear the data from google framework and restart the phone and see what happen :)
I just reflashed VI & VII and flashed the ICS theme, no problems with that. Thanks
