Root [Boost Mobile] [Theme] Warped Sandwich: Nb 7.0, CT 2.0 FINAL
Should ANWS keep N00b's VI's window animations?
  • Yes
    Votes: 16 57.1%
  • No
    Votes: 8 28.6%
  • Not important
    Votes: 4 14.3%
  • Total voters
    28
already did and still the same thing
Have you tried uninstalling the theme? What version are you using? CT or Nb? Updated version or non-updated version?
Did you clear dalvik cache and cache partition before you installed it? Are you coming from another rom?
You gotta give me more information if you're having trouble.
comming from Nb updated version... wiped dalvik and all and comming from rooted phone no rom... but i just switched to a diff rom and got it working anyway...
Updated. Changed the screen timeout and silence icons in the status toggle bar.
Also added a modified version of MrBobo's swap file (optional download) to make the N00b rom run faster and lag less. I adjusted the minfree values to be similar to Autokiller Memory Optimizer's "Extreme" setting, though much scaled back (130, 130, 150). The swap file is also increased to 1gb and swappiness to 100%.
A swap mod for CTMod is not yet available at this time.
Interesting, less lag in nOOb, I will have to check that out, not to say it lags at all........:D
Hehe, I hope you like it! Tell me what you think!
Well got the swappness already tweaked, had that done on the build done before his last update, its going to take a lot to over take what I have now, I will let you no sir..............:D
  • Like
Reactions: i2f
Make sure you back up your swap file! I probably should have written that somewhere.
This was the best config. I could make to eliminate the lag that I was having.
i2f, your call of course, but perhaps on your swap file you may wanna put the original beginning values prior to installing the file you created in case somebody has a lesser experience? Just a thought. In he past I would install rom updates out of excitement and not write down og settings and then kick myself for not. Lol Not necessary though and only if you have the time. :D Thanks for your hard work, as always!
Yep. I'm going to do that later today :-)
I just flashed CTMod 3.80. It's simply amazing, and there are a lot of new options and features! Because of this, updating Warped Sandwich to be compatible with this theme will take much longer than expected (days to weeks, rather than just a few hours).
But knowing me, you probably won't have to wait too long :)
Actually, it really wasn't that hard updating my initial release of Ice Cream Jelly for CT 3.75 to work on 3.80. There are differences, but not many (when it comes to theming at least :))
Quick question, I'm stuck trying to theme the phone.apk but I keep running into problems when recompiling. Figured I'd ask you since you themed it in 3.75? How'd you get it to build after making the changes?
I just used a program like 7 zip (pc) or better zip (mac) and explored the zip without extracting the files. Then I just dragged all of my edited images into the zip file and replaced the old ones. Then I just saved the zip. That's how I've been doing all of them this whole time.
Damn I haven't done something like that since I started theming while I was on noob VII... thanks! I'll try it out :)
I know I've said this before, and I know I've always gone back on my word, but this time, I'm serious. This will be the final version of Warped Sandwich for the ZTE Warp. My device recently became conveniently non-functional, which forced me to upgrade my phone to the HTC One SV. I no longer have my Warp, so I cannot update Warped Sandwich CT to be compatible with the latest version of the rom. For more support, I recommend using the Touch of Ice Cream Jelly Theme by Skinnyjeans21. It's an excellent theme that I've had the pleasure of testing before the end of my device's life. It's definitely worth checking out.
I loved theming for the Warp and hope you guys enjoyed what I've shared with you. Maybe I'll see some of you again on the HTC One SV forum :)
Do you mind if I help you out with porting it to CT3.80? I think others would love it as well, I know I would have..
