Root [Boost Mobile] [Theme] Warped Sandwich: Nb 7.0, CT 2.0 FINAL
Should ANWS keep N00b's VI's window animations?
  • Yes
    Votes: 16 57.1%
  • No
    Votes: 8 28.6%
  • Not important
    Votes: 4 14.3%
  • Total voters
    28
So this is what I've been working on lately (aside from job applications, which I should get back to doing).
I recently modified Go SMS (free) and the GOSMS Theme ICS ($0.99) to better match Warped Sandwich. I removed a lot of ugly from it. And by that, I mean, I made a few icons completely transparent so they're invisible.
I'd share it with the community, but since it's a paid app, I can't really do that.
I didn't show it, but the contact names are white, and the preview text is black, essentially hiding it.
What do you think?
adkls;jfdkl /asfjkl;as flv;sdajfl;ads;fjk.cvl;asdfh ,va/s.dkMCx,z
I JUST FIGURED OUT HOW TO CHANGE THE EXPANDER ICONS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I'd buy it! I use the kxnt blue ics go sms theme right now. I'll send a couple of screenies of how I customized it. Good job!
I've added the small blue separation line and changed the font to grey, bold/italic
Expect a final version of Warped Sandwich 4.0 in a few days. There are going to be a lot of surprise changes to the theme since R5. I'm pretty sure you're going to like them a lot :)
Can u fix it, so i can c exactly when a person call, ur text i believe is black and i cant c nothin.
I'm not sure what you're talking about. Where is it that the text is black? And also, that sounds like a coding-related issue. I don't and can't code. I merely replace and photoshop images.
Also, my theme incorporates MrBobo's black text fix for notifications.
if u press a recent call that been call 2 hours ago, it should say wat time exactly was the call but its just black, under outgoing call should be a time but its not there
I would take that issue to someone else because as I have said, I don't do any coding. I strictly theme by photoshopping. Thank you for bringing the issue up, but there is nothing that I can do to help you.
Just to reiterate, my theme should not have caused the issue because I simply photoshop images. All of that is CODE RELATED. Not image related.
press dialer, press call log, press a call, under outgoing call or incoming call, should be the time the call was made, say 8:42 for example, but there is no time, it use to be black but i think the theme color makes it not show
I did not edit those files. If I remember correctly, MrBobo initially themed the phone dialer in the Noob Rom. I'm pretty sure I know what I can edit and what files I have edited. I will say this again, my theme did not do that. If you don't like it and feel the need to complain about things that I have no control over, uninstall my theme - which I thought to share with the community for FREE - and get off my thread.
Officially released 4.0 with all new changes (refer to the change log). Also included an uninstaller, which will restore the phone back to stock N00b.
The thread is for the community, i thought ur theme change the coloring but dont get up tight, i like ur theme, just thought u could fix it.
As many people probably know by now, I have major depression and have symptoms that are very similar to borderline personality disorder. So it all combines into an automatically negative appraisal of things that occur in my environment - among other things. It usually takes a while for me to calm down to actually "check the facts" as my therapist puts it. For that reason, I am sorry for the over-reaction.
I added an uninstaller if you want to compare the theme to the stock appearance.
EDIT
I initially perceived your comments as suggesting that I'm some moron who didn't even know what changes he has made to something that he worked on for months. That's why I got up tight.
