Root [Boost Mobile] [Theme] Warpin Colors for n00b VI/VII/VIII
croy2007
Resident Punisher
Warpin Colors (Last updated: 2/20/13)
To install:
1) Place zip onto sd card
2) Go into Recovery
3) Make a backup
4) Install zip
5) Reboot
Disclaimer: I am not responsible for any damages to your phone.
Always looking for new ideas to add to the theme.
n00b VI/VII/VIII
Screenshots:
Themes:
V3B:
V3Bc:
V3Blc:
V3Rc:
V3Pc:
V3Oc:
Updates:
V3B n00b Signal Bars:
V3R n00b Signal Bars:
V3B Transparent Status Bar:
V3R Transparent Status Bar:
Changelog:
Still compatible to n00b VI/VII/vIII
V3Oc
Change multiple colors
V3Pc
Update to change to transparent status bar
v3R n00b Signal Bars
Update to change to n00b signal bars
v3Rc
v3B n00b Signal Bars
v3Blc
v3B & vB3c
Added Android 4.0 screen transition
Made compatible to n00b VI
v2.1 & v2.1c
Themed:
USB Connect
Power Menu
Made compatible with n00b V.I Update
v1.1c
Changed Battery Indicator
v1.1
Themed:
Volume Bar
Download Bar
Popup Window
Finish Lockscreen
v1
Themed:
Icons
Status Bar
Notifications
Lockscreen
Assisted by: LilBit
Downloads:
n00b VI/VII/VIII:
Themes:
Stock n00b IV/VII/VIII Theme
Blue:
Warpin Colors V3B.zip
Warpin Colors V3Bc.zip(Circle Battery)
Warpin Colors V3Blc.zip(Light Blue & Circle Battery)
Red:
Warpin Colors V3Rc.zip(Circle Battery)
Purple:
Warpin Colors V3Pc.zip(Circle Battery)
Orange:
Warpin Colors V3Oc.zip(Circle Battery)​
Updates:
Blue:
Warpin Colors V3B n00b signal bars.zip
(Must be installed over v3B or v3Bc)
Warpin Colors V3B Transparent Status Bar.zip
Red:
Warpin Colors V3R n00b signal bars.zip
(Must be installed over v3Rc)
Warpin Colors V3R Transparent Status Bar.zip
I wouldn't know why it works fine on my phone and a friend who tested it as well
Got to work I reverted back to stock theme, reinstalled this one with out clearing the caches. I probably didn't have to revert back to stock theme, oh well I got it and I'm happy thanks :D.
Tip for threads, drop your pictures in drop box and use the image button in the thread to make them display for people.
Great work by the way!
Could you fix the broken screenshots in op. And add one for 1.1c
I was working on the pics as you posted. Thanks for letting me know about the bad link, my computer doesn't show them. So I have to edit them threw my phone.
EDIT: I dont know why they are not showing on the phone. I can se them fine on my computer.
